I have a number of pieces of Composite Video/SDI/Timecode equipment to dispose of and am looking for modest offers to take them off my hands. There is a list below, please contact me if you want more information.
# Qty, Manufacturer Description
1 1 Avitel TPR 1040K Timecode Processor
2 1 Chromatec E-Series Mini Frame In-Vision 2 x 4-Ch Audio Meter Composite
3 1 Courtyard CY430 NTSC SPG and Pattern Generator
4 1 Daewoo DVD9000S5 DVD Player Composite, Scart out
5 1 Evertz 8950 Digital VITC Reader (SDI) Scratched front panel
6 1 Evertz ECM4010P EDIT CODE MASTER Versatile Timecode Reader/Generator
7 1 Link Electronics PSU 223/Pluge Gen 325/SPG 245 1U Rack unit with 3 test generator modules
8 1 Link Electronics PSU 223/Pulse & Bar 326/Sweep 328 1U Rack unit with 3 test generator modules No top cover, wrong FP on P&B module
9 1 Probel 6063 3U Frame with DA modules 5263 SDI DA x 5, 6255 Composite VDA x 4, 6246 Audio DA x 2
10 4 Quartz CP1601A CP1601A 16x1 Router Control Panel
11 2 Quartz CP3200 XY Router Control Panel Q-Link
12 1 Quartz Q16-AV-1616 16x16 Composite Router
13 1 Quartz Q1600-SV-1604-A 16x4 SDI Router
14 2 RBL MS5.6 Miniscript 5.6” Monitor Composite Monitor Composite in
15 1 RBL W15.6 Widescreen 15.6” Monitor Widescreen monitor SDI, Composite, DVI and VGA in
16 1 RBL W17 Widescreen 17” Monitor FHD Rack Mount Widescreen monitor SDI, Composite, DVI and VGA in
17 1 Rextron VSA12 VGA 1 in 2 out Video Splitter With separate PSU
18 1 Technika TKHVD214 DVD Player HDMI, Composite, Scart out
19 1 Tektronix SPG-422 Component Digital Generator
20 1 Tektronix TSG-271 Composite Generator
21 1 Tektronix TSG-300 Component Generator 2t Comms SDI x 2 Output Option fitted
22 1 Tektronix TSG95 PAL/NTSC Signal Generator Portable unit
23 1 Tektronix WVR-6100 AES Audio & SDI Waveform Rasterizer VGA Display required
24 1 TV-One 1T-DA8CVB 8 Output Composite VDA BNC connectors
25 1 TV-One 1T-FC-677 3G SDI extender with HDMI Output SDI in, SDI x 2 + HDMI out
26 1 TV-One 1T-FC-766 HDMI to 3G SDI Converter
27 4 Various HDMI to SDI converter HDMI in, SDI out With separate PSU
28 1 Various SDI to HDMI converter SDI in, HDMI out With separate PSU
29 2 Various 2U Rack mounting tray – black
30 2 Various Box of assorted BNC cables – mostly 0.3 – 3m long
31 1 Vero? Lightweight aluminium 19” equipment rack 55cm W x 60cm D x 182cm H
32 2 Various Box of black brick power supplies Mixture of 12V, 24V, 5V, various wattages.
33 1 Philips DVP3120/05 DVD Player Composite, Scart out
34 1 Link Electronics Type 315 Linearity Filter and Amplifier
35 1 Peca Video Isolating Transformer Potted in Eddystone Diecast Box BNC I/O
Equipment for disposal
Re: Equipment for disposal
Hi Richard
Where are you located (approximately)?
Warwickshire, near Stratford-upon-Avon.
Richard
Richard
This equipment is no longer available.
Richard
Richard
