BATC Repeater controller - Getting it up and running
Posted: Sat Feb 15, 2025 9:48 pm
Hi, I'm in the process of building the BATC logic controller for GB3CT, but I have run into an issue while testing what I have built so far. I'm hoping someone can assist.
The basic setup is 6 inputs across 2 cascaded PORTA HDMI switches using the dual IR drive circuit which I have driving a pair of IR and visible LEDs (so I can visually monitor the IR bursts on both channels). I have tested the circuit by toggling the select and drive logic levels and I am happy that it is working as it should as the inputs change to 1 on the switch on boot-up. However, the PI does not seem to output any drive to the IR LED circuit on any input selection.
The 6 inputs don't seem to do anything, so I have tried monitoring what is going on using the logging facility but upon each input selection across any of the 6 inputs, the log just repeatedly shows input change detected, monitoring de-bounce when each input is activated. It doesn't appear do anything more. Should the log file indicate successful selection or anything? I'm using the latest software build.
Any help would be appreciated.
Thanks, Jason
Thanks, Jason
