Following a request (and some code snippets) from Rob VK3TRX, I have added support for the use of an ATEM Mini Pro as the HDMI switch in the BATC Repeater Controller (Version 202311150).
Full details can be found here https://wiki.batc.org.uk/Configuring_ATEM_Control
Please report any bugs here.
ATEM Switching for BATC Repeater Controller
Re: ATEM Switching for BATC Repeater Controller
Hello Dave,
I'm currently converting my own repeater control to the ATEM.
However, I use compenion for this.
First of all, you can set up the ATEM using Blackmagic's control software.
You can assign both HDMI outputs.
So you can switch both outputs to the MultiSource.
You can import various multisource templates and then save them in the setup. This setup will be loaded again when you switch on.
You can switch the audio inputs (including the analog ones) on and off.
With compenion you can change a lot of settings.
You can easily trigger/switch this on/off from a control program using webhooks.
This is only a small part of the possibilities.
Justin G8YTZ gave me a lot of help.
He also uses an ATEM for his repeater control in the GB3JV repeater.
