PIPO X8 Screen res
Posted: Sat Jan 14, 2017 3:48 pm
by G1LWX
Hi all
I have just obtained a second hand PIPO X8 with windows 10 installed.
The problem is that I cannot set the screen resolution for tuitoune software
the max size is 800 x 1280 and at best part of the display is missing.
Is there a software update that I can use I have tried a few but i'm not
having any success.
73s Mike
Re: PIPO X8 Screen res
Posted: Sat Jan 14, 2017 6:33 pm
It should work - are you using Minitioune 0.4c or Minitioune V0.5a ?
Posted: Sat Jan 14, 2017 6:39 pm
by G1LWX
Hi there
I am using version 0.5a and also tried 4c
the rh side of the tuitoune monitor is missing
the screen res needs increasing but it only goes to 800 x 1280
Posted: Sat Jan 14, 2017 7:13 pm
Edit the ini file so it doesn't open up in expert mode
Posted: Sat Jan 14, 2017 7:32 pm
by G1LWX
Thats sorted it many thanks
Posted: Wed Mar 01, 2017 6:49 am
by F6DZP
I suppose that you have applied a zoom factor to your PIPO display.
Minitioune software, in Expert mode takes 1086 x768 pixels so can been seen completely with a PIPO X8.(1280 x 800)
Jean-Pierre F6DZP
Posted: Thu Mar 02, 2017 11:39 pm
by G0MXW
Mike,
as Jean-Pierre says display is zoomed in. Microsoft set default zoom to 125% in Millenium update. Goto start, settings, system, display, and drag the slider under "change the size of text, apps...."all the way to the left to restore to 100%.
G0MXW
Posted: Fri Mar 03, 2017 12:07 pm
by mankell
Had the same issue and what GOMXV wrotes works. Have a go at it Mike. Thnx for the help btw.
Posted: Fri Mar 10, 2017 7:25 pm
by G1LWX
Thank's all
Yes I missed that one. All ok now.
