DVB-T Narrow Band Testing between G4NZV & G4FRE
G4NZV
Re: DVB-T Narrow Band Testing between G4NZV & G4FRE
Post by G4NZV » Fri Jun 17, 2022 6:53 pm
John,
Thanks for the update on your equipment setup for NBDVBT. I have not tried any of the software mentioned not even Windows 11 so I guess it works OK for NBDVBT. I have attached the Radioconda GNU version 3.9.5 for the RTL as a .zip file containing two files .grc and .py. (Thanks for the tip Noel).
Important: Do NOT change the file names otherwise the spectrum display will not be calculated correctly. Also ensure both files are in the same Folder.
Feedback welcome.
73 Steve G4NZV
dvbt_rtl_rx_qpsk_v395002_bandwidth_decim_factor.zip
(5.44 KiB) Downloaded 981 times
