6m DATV Sporadic E
Posted: Mon Jul 04, 2022 5:12 pm
by M0DTS
Hi All,
I'm now setup again for DATV on 51.7MHz.
If any European (or uk) stations want to try I can be available for tests.
Tx: Adalm Pluto, 100W DVB-S2 to 5el Yagi
Rx: PGA103 LNA > narrow Band Pass Filter > Ham-it-up converter to 176.7MHz for Minitioune Rx.
I Prefer 125Ks as I have QRM either side of 51.7, but 250Ks maybe possible.
IO94IL
My Rx Spectrum below, this is after phase/amplitude cancellation of a lot of noise!
The two peaks along with many smaller ones wander about +/-50KHz.
I have to improve the noise gathering antenna a bit yet........
- 6m Rx M0DTS.jpg (123.28 KiB) Viewed 13127 times
UPDATE!!
An hour later and a better 'noise reference' antenna i have reduced the QRM a lot!
Spectrum vs Rx with 125Ks test signal.
This should be sensitive enough now:
- 20220704_185654.jpg (120.98 KiB) Viewed 13122 times
- 20220704_185701.jpg (191.09 KiB) Viewed 13122 times
Re: 6m DATV Sporadic E
Posted: Mon Jun 05, 2023 9:41 am
by pe1itr
It's the month of June. Top of the VHF Es season.
I am QRV on 6m DATV on 51.7 MHz and available for skeds.
Transmitter is DVB-S(2) 30 watts. It's a Portsdown4 with pluto then with filters and amps. The output stage contains 2xMRF300. Receiver is a mini-touner with a series of up and down converters in front of it. Inside the 9 MHz IF is a 400 kHz wide band filter to get rid of unwanted signals.
With Es propagation I will occasionally turn the TX on with a test image and 125 ks. When I'm home the antenna is a dipole for now. There are also a number of wedsdrs active that go up to 52 MHz with which I can monitor the signal.
When "portable" the antenna is a 7 meter long 6el LFA yagi modified for 51.7 MHz. I expect 6m to be a good band for airplane scatter as well. The pad losses are on average 6 ~10 db lower than at 2m.
73 Rob PE1ITR
Posted: Tue Jun 06, 2023 3:57 pm
by M0DTS
Hi Rob,
I'll try to be active after on 6m from home again a few days after the contest, but currently setup for 29MHz.
The path between us is not good for A/S or Tropo and a bit short for Es... but we can try.
I don't think i can fit both 6m and 10m antennas on the mast here!
Luckily my QRM has now gone
I have ~100W to 5el on 6m and ~150W to 3el on 10m.
Another Rob
Posted: Tue Jun 20, 2023 1:56 pm
by M0DTS
I'm QRV on 6m DATV
Default to 125Ks 1/2 DVB-S but I can change as requested.
I'll be on this week after 14:00utc and most of the weekend if you want to try any tests around Europe...
Talkback on dxspot.batc.org.uk or Zello '50MHz Digital Amateur Television' channel.
Posted: Tue Jun 20, 2023 2:21 pm
I can also do 6m DATV, if I set it up. I have put 29 MHz back in the box for the moment as conditions have not been so good. Most likely trans-Atlantic two-way will be somewhere like Brazil or Canada as the FCC don't seem to allow anything more than a few kHz wide. South Africa is a good possibility too.
Posted: Thu Jul 20, 2023 5:40 pm
by pe1itr
I have my DATV station on 51 MHz ready. Made a two-way QSO with ON7MOR as a test last week. It seems to be working all right. On my website I have created a page with the current status of the station:
http://pe1itr.com/50mhz/datv-6m-2.htm
On Sunday August 20, 2023 I will be in the DATV contest on 6m/2m QRV from LX (JO30BA). First at 6m and then I convert to 2m.
On Thursday, August 31, 2023 in the evening and on Friday, September 1, 2023 in the morning/evening I will be at 6m QRV from Texel Island (JO23QK).
Zello channel "50MHz Digital Amateur Television" as talkback
73 Rob PE1ITR
