Page 2 of 4
Re: IARU Region 1 ATV Contest 11/12 June 2022
Posted: Sun Jun 05, 2022 8:16 pm
by G4FRE
I use:-
1298.5, 2322.5, 3402.5, 5762.5 10370.5 47090.5 and 75978.5MHz all dictated by using a 146.5 MHz IF with my narrowband transverters. I dont use a 2m "inband" IF frequency as I have had breakthrough issues from local signals (such as last tuesday morning with Gareth)
on 6cm FMTV i use 5665MHz
on 24GHz where I have a 70cm IF I use 24049,0 as 24050.5 is effectively "out of band"
G4FRE
Posted: Wed Jun 08, 2022 10:46 am
by G4FRE
This year I will be operating up North, as I am on a weeks walking holiday the week after the contest in Ravenscar. After much consultation with Rob, the plan is:-
Garrowby, IO93OX on Saturday - 1pm to 6pm at the latest.
Wharram le Street, IO94PB on Sunday - 9am till at the latest 3pm
I will have 2GHz and above DATV and 6cm FMTV Talkback on 433.50FM, 144.650FM, zello and 07941541592
After the holiday finishes I will also be trying a 111km path with M0DTS/P in the afternoon of June 17 from Rosedale IO94MJ before returning south
G4FRE
Posted: Wed Jun 08, 2022 11:29 am
by G8KOE
On Saturday I will be monitoring 144.750MHz talkback from home QTH in Somerset IO81LE most of the day.
I have 437MHz TX and RX untested with another station.
1255MHz TX tested RX should be working but untested with another station.
Dave G8GKQ I will listening on talkback for you and will also put out some calls should be from about 1330
On Sunday morning will be monitoring 144.750MHz talkback
Martin
G8KOE
Posted: Thu Jun 09, 2022 11:08 am
by GI4DOH
I hope to be QRV on 70cm and 23cm from IO74CO both afternoons.
Is there any set standard for DVB-S or DVB-T with SR and FEC?
Probably a good idea for me to try things out before I go.
I will have Zello and 07411443449
Richard GI4DOH
Posted: Thu Jun 09, 2022 11:28 am
Hi Richard
Probably too far away from me unfortunately, but I would suggest:
436.5 MHz 333 Ks FEC 2/3 DVB-S2 H264
and
1255 MHz 333 Ks FEC 2/3 DVB-S2 H264
You may have to change the frequencies due to radars in your area.
The SR/FEC combinations are a compromise between weak signal performance (lower SR and FEC is better, as seen on QO-100) and the time it takes to get a valid picture in fading (higher SR and FEC is quicker). DVB-S2 is the most efficient mode; DVB-S is a few dB worse. All our tests with reduced bandwidth DVB-T so far have been very disappointing and I would not recommend it as a DX mode.
Hope that helps
Posted: Thu Jun 09, 2022 12:44 pm
by GI4DOH
Thanks for the info Dave - that removes some of the variables for me.
I’m starting from zero so any QSO would be a major achievement
Kit running nicely off 12v battery so almost ready to go.
Apologies for QO-100 net tonight - club BBQ in the rain beckons.
Richard GI4DOH
Posted: Thu Jun 09, 2022 2:30 pm
by M0DTS
My site on Saturday is not favourable to the west but Sunday site should be ok, happy to give it a try Richard.
I will be on Zello plus 144.750 and occasionally dxspot if i get time.
Mobile 07999796421.
Posted: Thu Jun 09, 2022 6:24 pm
by M0YDH
Hello
I intend to go to Magpie Hill above Clee Hill village IO82RJ on both Saturday and Sunday. I received G8GKQ fron Dorset, Arthur g4cpe and Steve M0SKM in Bedfordshire and had 2 way contacts with Graham G3VKV in Cheltenham from there last year. It's screened from NATS radar on Titterstone Clee Hill. This year I hope to make more transmissions and contact Noel.It sounds like he's a moving target.
I'll probably take everything I have built! So if you want to attempt 51.7 or 71MHz DVB-T or S2 do say. I may be twiddling my thumbs like last year and be glad of the activity. So I'm setting up for 146.5, 437, 1255 digital and 5.6GHz FM.
144.750 FM talkback or 2m SSB even. ATV South on Zello. 07951313547 for when things are going awry.
New member Andy G7CFC is joining me on Sunday.
All the best in the contest.
David M0YDH
Posted: Fri Jun 10, 2022 6:41 am
I will be on from home IO91IO on VHF/UHF. I have another event on Sunday afternoon so only active in the morning. Talkback 144750 and Zello South.
Posted: Sat Jun 11, 2022 6:32 am
by g0uhy
I'm hoping to be on from home IO80EK98 at various times over the weekend. 23cm, 70cm and maybe 3cm. Tb 144.750+/- and maybe Zello. Also on my mobile: 07802 200920.
Malcolm G0UHY
