BATC SummerFun/InternationalContest 13 - 14 June 2015
Some more news about this year's BATC Summerfun ATV Contest, which coincides with the IARU Region 1 International ATV Contest. Highlights:
- Contest runs from 1pm on Saturday 13 June until 7 pm on Sunday 14 June
- All bands from 70 MHz upwards.
- BATC Award for best DX using 800 KHz bandwidth (or less) RB-TV on any band, with a £50 Amazon Voucher for both stations involved.
- Contacts on 432 MHz and above count towards the IARU International ATV Contest
So, it's time to check your portable gear, apply for your 70 MHz Special Research Permit, and get building!
More details to follow.
BATC Contest Manager
Potential /p sites in Wales?
I am going on holiday the week before the summerfun contest and won't arrive home until the Saturday afternoon - bad timing I know, but maybe I could turn it to my advantage if I can find a good /p site in mid /south / east Wales that I can drive on to. Any suggestions??
Also I will be staying very near GB3GW so if I take the gear, I might be able to put some pictures in on 23cms....
Re: BATC SummerFun/InternationalContest 13 - 14 June 2015
Here are my plans for the ATV Contest 13/14th June:
On the Saturday i will be at IO94DE Ellingstring, nr Ripon - Active from 1pm until activity runs out!
This site has good takeoff to South East round to north, nothing to the west or due south unfortunately.
On the Sunday i will be on the IO94MJ North York Moors - Active from 10am onwards unless there's a hint of early tropo
Good Take off in most directions at 1200ft Asl
I will be active on all bands from 146MHz -> 24GHz, with low SR DATV possible on all bands except 6cm.
I will have analogue still on all bands above 146MHz.
Hopefully that caters for every possibility ?!
If anyone wants to come along and help or just see what goes on then please let me know.
The current plan is to go to Blorenge mountain above Abergavenny (IO81LS) which has very good take to the east round to the south west - but unlikely we will work Rob.
I will have 146.5 RB-TV, 437 MHz DATV and 23cms ATV & DATV and be there from 12 noon for about 5 hours dependeing on activity (and Sally's Kindle battery)!
I will be out near home (not confirmed where) on Sunday and may have 10 GHz rx
I will have DXspot.tv and mobile phone but only mobile whip on 144.750 - it would be good to set up some scheds before hand to make sure it is worth taking all this gear (and a trailer) on holiday up to North Wales....
Please Post your anticipated activity in the contest here.
I hope to be out /P somewhere North of Southampton on Saturday afternoon with 70 cms and 23 cms analogue and digital. Possibly 13 cms and 3 cms as well. Contact via 144.75 MHz FM or http://DXSpot.TV chat.
Change of plan...
I will not be /p from Wales on Saturday but will be out on Saturday afternoon / Sunday from IO91 square, hopefully from a site with good take off to the North.
Hope to work you all - pm me if you want to set up a sched, if not see you on dxspot.tv
GW3NWR should be at Rhosesmor, North Wales on the Saturday only with 23cm analogue / digital, plus 70cm and 3cm receive.
- G1LPS Terry
Active on all bands 2m - 24ghz
From io94eq
From io94eq
IARU International Contest UK Results
I have just submitted the UK Entries for this year's IARU ATV Contest. Here are the results as submitted.
Congratulations to Terry G1LPS for winning, and also to Rob M0DTS for coming a close second (and gaining more points than Terry, but from 2 locations!). Thanks to everyone who took part and made it such a successful day.
The results band-by-band are here:
I will publish the results of the Summerfun Contest (which will include RB-TV contacts on 70 and 144 MHz) in a few days.
BATC Contests Manager
Pos Call IARU points
1 G1LPS 2424
2 M0DTS/P (1) 2388
3 G4KLB 912
4 G8GTZ/P 650
5 G4CPE 424
6 G8ADM 378
7 M0DTS/P (2) 294
8 G3KKD 175
9 G8GKQ/P 130
10= G3UEQ 10
10= G4GUO 10
70cm
Pos Call Points Best DX QTH Dist
1 G4CPE 424 G8GTZ/P IO91GI 95
2 G8ADM 378 G8GTZ/P IO91GI 80
3 G8GTZ/P 350 G8ADM IO91SW 95
4 G4KLB 324 G8LES IO91LC 72
5 G3KKD 175 M0SKM IO91RV 63
6 G8GKQ/P 130 G4KLB IO90BR 60
7= G1LPS 102 M0DTS/P IO94DF 51
7= M0DTS/P (1) 102 G1LPS IO94EQ 51
9= G4GUO 10 G3UEQ IO90TU 5
9= G3UEQ 10 G4GUO IO90ST 5
23cm
1 G4KLB 588 G8GTZ/P IO91GI 75
2 G8GTZ/P 300 G4KLB IO90BR 75
3 M0DTS/P (2) 294 G7AVU IO93OJ 112
4 G1LPS 282 M0DTS/P IO94DF 51
5 M0DTS/P (1) 246 G1LPS IO94EQ 51
13cm
1= G1LPS 510 M0DTS/P IO94DF 51
1= M0DTS/P (1) 510 G1LPS IO94EQ 51
9cm
6cm
3cm
IARU International Contest Results
The International Results for this contest have been published here: http://www.iaru-r1.org/images/VHF/atv/I ... _2015a.pdf
Congratulations to M0DTS who was the highest-placed UK entry as his scores from his 2 operating sites were combined.
A really good contest, with 47 entries in total including 11 from the UK. The map on the last page of the results shows the geographical spread of all the active stations across Europe.
Let's try to get 50 stations on the air for the next activity weekend on 12/13 September!
