BATC Repeater Contest 21/22 March 2015
Post by G8GKQ » Mon Mar 09, 2015 8:24 am
Don't forget that the BATC Repeater Contest runs from 1200 UTC on Saturday 21 March until 1800 on Sunday 22 March. Time to make use of your local (and distant?) ATV Repeaters.
The rules can be found here: http://www.batc.org.uk/contests/BATC_Re ... _Rules.pdf
The Excel (or Calc) spreadsheet for submitting your results is here: http://www.batc.org.uk/contests/Logshee ... peater.xls
Re: BATC Repeater Contest 21/22 March 2015
Post by G8GKQ » Wed Mar 18, 2015 5:31 pm
Please post here if you will be active on any repeaters over the weekend.
Let's try to publicise some activity!
G8DKC
Post by G8DKC » Fri Mar 20, 2015 1:54 pm
As GB3GV stream is down, will stream "off air" via G8DKC.
Peter
BATC Repeater Contest 21/22 March 2015 - Results
Post by G8GKQ » Sat Jul 11, 2015 12:19 pm
My sincere apologies, I had forgotten to calculate the results for this Contest!
The only activity was through GB3HV which, although receiving normally, was not transmitting except via BATC.TV. There were 3 entries:
Pos   Call   Points   Contacts  Repeater
1     G8ADM  245      3         GB3HV
2     G0EID  238      3         GB3HV
3     VK2CRJ 130      3         GB3HV
Thanks to the 5 stations that took part (G8GTZ and G8DGR were also active) and congratulations to Dave, G8ADM.
BATC Contest Manager
G8ADM
Post by G8ADM » Wed Jul 15, 2015 10:58 am
WoW, I won a contest, first one ever I think!
It was not much of a challenge though.
How can we get more interest in the Repeater Contest?
Thanks all,
Dave.
G8adm
