The UK entrants to the 2020 IARU contest logged 204 QSOs in bands from 435MHz to 76GHz. 70cm is still the most popular band with 44 QSOs, followed by 23cm on 38 QSOs and surprisingly at third is 9cm with 26 QSOs which has beaten 13cm in fourth place with 25 QSOs. With large numbers of stations tooled up for the QO-100 uplink I was expecting more from 13cm. The best DX was on 23cm between Terry G1LPS and M0MLJ at 163km.
Overall wInner of the UK section is Noel G8GTZ/P with 19826 points, who managed to get points on all bands from 435MHz to 24GHz inclusive plus 76GHz, very impressive!
Here are the full UK results (CORRECTED 11/08/20); well done to Dave G4FRE and Dave G8GKQ who have come second and third respectively:
1 G8GTZ/P 19826
2 G4FRE/P 13898
3 G8GKQ/P 13027
4 G4LDR 6425
5 M0DTS/P 6197
6 G1LPS 4563
7 G0MJW 1222
8 M0YDH/P 1151
9 G8VPG/P 736
10 M0DHP/P 456
11 G3KKD 322
12 G4CBW/P 264
13 G4XAT 24
14 G4HJW 20
14 M0PIT 20
The UK only contest received no entries for the 4m band but 2m saw 10 QSOs from 7 entrants. Best DX was between Dave G8GKQ/P and David M0YDH/P at 145km. Congratulations to the winner Sean G8VPG/P
Nr Call Score
1 G8VPG/P 435
2 G0MJW 290
3 G8GKQ/P 290
4 M0YDH/P 281
5 G3KKD 56
6 G4XAT 24
7 M0PIT 10
Leaders by band are as follows
70cm M0YDH/P
23cm G1LPS
13cm to 12mm G8GTZ/P
4mm shared between G4LDR/P and G8GTZ/P
Thank you to everyone that submitted logs demonstrating our use of the bands.
Clive G3GJA
BATC Contests Manager
UK results for the 2020 IARU ATV Contest
- G1LPS Terry
Re: UK results for the 2020 IARU ATV Contest
Thanks Clive
Wow some big scores there.
Well done Noel that's the highest UK score I can remember.
Is there a break down for the section 1 and section 2 winners in the UK
Terry
Terry
Hi Terry
Section 1 results are as follows:
Nr Call IARU score
1 G1LPS 4563
2 G0MJW 1222
3 G3KKD 322
4 G4XAT 24
5 G4HJW 20
6 M0PIT 20
Well done Terry!
For completeness, here's the Section 2 results table:
1 G8GTZ/P 19826
2 G4FRE/P 13898
3 G8GKQ/P 13027
4 G4LDR 6425
5 M0DTS/P 6197
6 M0YDH/P 1151
7 G8VPG/P 736
8 M0DHP/P 456
9 G4CBW/P 264
Not surprisingly, there's no change in the first five places compared with the overall IARU result.
Clive G3GJA
Nr Call IARU score
1 G1LPS 4563
2 G0MJW 1222
3 G3KKD 322
4 G4XAT 24
5 G4HJW 20
6 M0PIT 20
Well done Terry!
1 G8GTZ/P 19826
2 G4FRE/P 13898
3 G8GKQ/P 13027
4 G4LDR 6425
5 M0DTS/P 6197
6 M0YDH/P 1151
7 G8VPG/P 736
8 M0DHP/P 456
9 G4CBW/P 264
Clive G3GJA
