146 and 437MHz contest Aug 8th and 9th
Post by g8gtz » Sat Aug 01, 2020 5:48 pm
The 146 and 437MHz contest is next weekend.
I will be on from home IO91KF at times on Saturday but don't expect too many contacts!
On Sunday I will be out portable, probably from Walbury Hill IO91GI near Newbury with good take off in all directions.
The 2 easy bands should make it a fairly enjoyable occasion and I look forward to hearing your plans for the weekend :-)
Noel G8GTZ
Re: 146 and 437MHz contest Aug 8th and 9th
Post by radiogareth » Sat Aug 01, 2020 5:58 pm
If things quieten down here I should be out on Sunday, only 146MHz, form my usual location IO91XH Woldingham Surrey.
Post by M0DTS » Mon Aug 03, 2020 8:43 pm
I'm planning on being out portable Saturday from ~11am at IO94LI.
I'l be on from home on Sunday.
2/70 plus most other bands most likely.
Post by G8GKQ » Tue Aug 04, 2020 12:01 pm
Just for clarification, the Contest will run from 1200 UTC (1 pm UK Local) on Saturday 8 August until 1800 UTC (7 pm UK local) on Sunday 9 August. The rules will be exactly the same as for the IARU International Contest, except the only bands will be 146 MHz and 437 MHz. Multiplier for both bands is 2 points per km for a two way contact, and half that for a one-way contact.
The basic rules are here: https://www.iaru-r1.org/wp-content/uplo ... -rules.pdf, but please note that entries should be sent to "contests@batc.tv".
The logsheet for entries is here: https://wiki.batc.org.uk/images/d/d5/AT ... 190608.xls
Hope to see many of you on the air this weekend.
