Digilite configuration
F1CJN_alain
Post by F1CJN_alain » Wed Sep 07, 2011 3:40 pm
When i try configure the PID audio, for exemple to 31, with the Digilite configuration program , the Digilite transmit program V1-4 shows an 257 audio PID ?
For the PID video , I can modify it and the Digilite transmit program shows the right video PID information.
It looks right also for the PCR modification and information.
Any idea to change the PID audio?
Best regards
Alain
F1CJN
Re: Digilite configuration
Post by G4EWJ » Wed Sep 07, 2011 5:15 pm
PIDs below 32 are reserved for special DVB functions.
DigiLite Config v1-40 should beep if you try to save with any of the PIDs < 32 or > 8190.
F1CJN_alain
Post by F1CJN_alain » Sat Sep 10, 2011 9:24 pm
Audio PID still fixed at 257 in the Digilite transmit program.
I tried audio PIDs of 49, 482, 8000 and many others. When I modify the audio PID, the Digilite transmit program restart normally but always with an 257 audio PID.
Everything is right for the Video and PCR Pids.
Alain
F1CJN
Post by G4EWJ » Sun Sep 11, 2011 5:02 pm
I can see where the problem is occurring. I'll produce a new version shortly and let you know when it's ready.
Thanks for letting me know.
F1CJN_alain
Post by F1CJN_alain » Tue Sep 13, 2011 9:25 am
Everything is right with the new fresh version "Digilite transmit V1.40 B".
You can put put online.
Thanks a lot.
Regards
Alain
F1CJN
Post by G4EWJ » Fri Sep 16, 2011 3:17 pm
Good.
I'll fix the problem with the test mode sidebands In DigiLite Config v1-40 and then ask G8AJN to put them both on the DigiLite site as the standard release.
Return to “DigiLite”
