Page 2 of 2
Re: MK808/DigiLite
Posted: Thu Dec 26, 2013 11:49 am
by G4EWJ
Are the TS settings stored on the micro SD card? If so, it would be easy to have a card for each configuration.
Re: MK808/DigiLite
Posted: Thu Dec 26, 2013 5:49 pm
by M0DTS
On the controller version the TS settings are stored in the controller so the sd card will not make any difference.
For the non controller version the settings are created when you run the nocontroller script so you could have separate sd cards with different settings.
If you were clever you could write another script to allow settings to be changed on the no controller version via WiFi / web interface....
Problem with that is you need to setup the WiFi which I'm not too good with on the 808!
Re: MK808/DigiLite
Posted: Sat Dec 28, 2013 9:37 pm
by M0DTS
This evening i picked up a 29xxx version pvr from Terry G1LPS.
Found the problem, the 29xxx version uses some extra driver modules compared to 24xxx version - saa7115 & msp3400.
The 29xxx version now works with mk808
These files have now been added and i will upload a new sd card image tomorrow morning - 28th.
Also testing a 24022 NTSC version to see if it allows PAL operation, currently only NTSC... I will post results if any joy.
[ Edit: 24022 version will only accept NTSC signal input, no reason you cannot use it if you have an NTSC TV but away from the standard. ]
Re: MK808/DigiLite
Posted: Sun Dec 29, 2013 2:54 pm
by G4EWJ
On the PIDs, it would be useful to be able to enter all of them.
I don't have the no controller version here at the moment. What do the PCR and PMT PIDs default to? We use GB3UD settings for simplex contacts in this area and some receivers which had previously scanned standard DigiLite transmissions weren't able to lock on just by entering the video and audio PIDs.
Re: MK808/DigiLite
Posted: Mon Dec 30, 2013 3:01 pm
by M0DTS
Ah yes, UD input has PMT of 32 or something near that... will look into it.
Currently these are the settings:
PCR is the same as the Video PID which i think is standard?
PMT is 4095, same a DigiLite default.
I think PMT makes the most difference to decoding or not when the receiver sees a different value, it comtains the information about what the other pids are.
Re: MK808/DigiLite
Posted: Wed Jan 01, 2014 11:56 am
by F1CJN_alain
Thanks Rob for the 29xx version. I will test it when I'll return home, next Thursday.
Happy new year to all the DA-TV enthousiats.
Alain
F1CJN
Re: MK808/DigiLite
Posted: Wed Jan 01, 2014 11:44 pm
by G4KLB
