				PA's for 23cms Digilites?
				Posted: Tue Nov 05, 2013 12:03 pm
				by Basil
				What are my choices for PA's for the Digilites? Preferably commercially made, but would consider a kit if known to be 100% OK. I do actually have some nice
big heat sinks, and 12 or 50V high current supplies, come to think of it. Thanks.
				Re: PA's for 23cms Digilites?
				Posted: Tue Nov 05, 2013 6:51 pm
				by g8ajn
				The output from the DigiLite modulator section is very low, typically 1 or 2mW, and one or two stages of amplification will be required to get to the 150-200mW input required by the RA18H output brick (500mW for dual version). A MMIC followed by a more powerful amplifying device such as RF2126 is a typical arrangement, some lower power bricks or even an under-driven RA18H brick can be used as a driver.(with suitable attenuation). It is important not to overdrive the input to the RA18H, not only to avoid unwanted distortion of the ultra-linear digital signal, but also to avoid permanent damage to the first stage of the brick. There are a number of Ebay shops supplying suitable kits, search for 'rf amplifier'. MiniKits in Australia have a useful collection of amplifier kits. A browse through the BATC Forum will also reveal a number of useful links If you are handy with homebrew pcbs you might try this design from 9H1LO.
Copied from
http://www.g8ajn.tv.
Dave G8AJN
