I have successfully setup 3 DigiLite Ver 5.7 boards. Here is an easy procedure I've worked out.
Use the Digilite configuration program to set TEST MODE to "IN PHASE"
Make sure the symbol rate matches the Nyquist filter frequency, (4000K typ)
Use an oscilloscope to set the I drive level at IC3 pin 7. Adjust Level pot R23 and Bias pot R29 for a 2 volt peak to peak sine wave signal swinging from 1.4 VDC to 3.4 VDC.
Set the Q drive level at IC3 pin1 using Level pot R16 and Bias pot R30 for the same waveform.
You will likely have a passable signal at this point. To finish the setup connect a spectrum analyzer and tweak the Bias pots to null out the carrier.
DigiLite Setup Procedure
Jump to
- Forum Admin
- ↳ Announcements
- ↳ Feedback
- ATV General Discussion
- ↳ Getting Started?
- ↳ General ATV Discussion
- ↳ DATV - Digital ATV
- ↳ ARISS HamTV
- ↳ LimeSDR Mini
- ↳ CAT 25 Part 1, 3 August 2025
- ↳ CQ-TV, The BATC Magazine
- ↳ BATC Bursary Grants
- ↳ Spectrum matters
- ↳ Streaming
- ↳ EMF Compliance
- ↳ Narrow Band DATV (RB-TV)
- ↳ DXSpot.TV
- ↳ Deutschsprachiges Forum
- ↳ Events
- ↳ DigiThin
- ↳ DigiLite
- ↳ BATC DTX1
- ↳ CaribouLite RPi Hat
- Adverts
- ↳ For Sale
- ↳ Wanted
- ↳ BATC Shop
- ATV Repeaters
- ↳ UK ATV Repeaters
- ↳ GB3BH
- ↳ GB3CZ
- ↳ GB3DK
- ↳ GB3EN
- ↳ GB3ET
- ↳ GB3EY
- ↳ GB3FB
- ↳ GB3FT
- ↳ GB3FW
- ↳ GB3FY
- ↳ GB3GG
- ↳ GB3GV
- ↳ GB3GW
- ↳ GB3HV
- ↳ GB3IF
- ↳ GB3IT
- ↳ GB3IV
- ↳ GB3JT
- ↳ GB3KM
- ↳ GB3LO
- ↳ GB3LX
- ↳ GB3MV
- ↳ GB3NQ
- ↳ GB3NV
- ↳ GB3PV
- ↳ GB3RT
- ↳ GB3RV
- ↳ GB3SQ
- ↳ GB3TG
- ↳ GB3TM
- ↳ GB3TN
- ↳ GB3TT
- ↳ GB3TV
- ↳ GB3TZ
- ↳ GB3UD
- ↳ GB3VR
- ↳ GB3UT
- ↳ GB3VL
- ↳ GB3VV
- ↳ GB3VX
- ↳ GB3WV
- ↳ GB3YT
- ↳ GB3ZZ
- ↳ Internet-only Repeaters
- ↳ IO91LC
- ↳ IO91WN
- ↳ IO92GQ
- ↳ Overseas ATV Repeaters
- Archive
- ↳ GB3AT
- ↳ GB3FT
- ↳ GB3FV
- ↳ GB3CT
- ↳ GB3AD
- ↳ GB3BG
- ↳ GB3DH
- ↳ GB3DJ
- ↳ GB3KT
- ↳ GB3NV
- ↳ GB3OT
- ↳ GB3PT
- ↳ GB3TB
- ↳ GB3TX
- ↳ GB3VW
- ↳ GB3XG
- ↳ GB3XT
- ↳ GB3XV
- ↳ GB3XY
- ↳ GB3YT
- ↳ GB3YX
- ↳ For Sale Ads Archive
- ↳ Wanted Ads Archive
- ↳ CAT 16 and BGM 2016
- ↳ CAT 17
- ↳ CAT18
- ↳ Mini-Conventions in 2019
