no more need PVR150: DV input is possible 16/9 and HD
F6DZP
Re: no more need PVR150: DV input is possible 16/9 and HD
Post by F6DZP » Thu Apr 19, 2012 12:47 pm
D1 mode is 720x576i that becomes on display LCD 768x576 for 4/3 format or 1024x768 for 16/9 format.
the C525 give directly 1024 x 576p - 16/9 that correspond to D1 display, but directly with "square pixels" not anamorphic mode as 720x576 is.
If you use a computer for receiving, there is no problem.
if you use an old basic setTop box with only a SCART output, there were be difficulties.9/10 you will see nothing
if you use a modern setTop box that can receive DVB-S2, H264 decoding,with HDMI output it should be able to show the video.
30 fps is not a problem as it correspond to NTSC synchro
Jean Pierre F6DZP
Return to “DigiLite”
