SDR-Kits 70cm Synth VCO kit build
M0ATV
Post by M0ATV » Mon Jan 23, 2012 10:41 pm
Finally finished off the 70cm Digilite board last week, so have eventually got around to constructing the SDR-Kits synth vco LCD kit for it, the board itself seems quite easy, but the 14 way ribbon cable looks a bit fiddly to attach to the header plug, will finish the vco off tomorrow, wondered if there was anyone else who is using this vco, after this its just the SUP-400 up converter for RX & 70cm datv hopefully will be up & running.
Return to “DigiLite”
