SUP-2400 for 70 Cms.
Posted: Tue Jan 03, 2012 5:48 pm
Hi All .... Has anyone worked out how to activate the up converter without having to solder in the link wire from the 5 volt regulator and sniping pins 14, 17 and 18 off the chip ?
I have modified two and they both work. It is only necessary to link the reg. to the pads from the sniped leads 17 and 18.
5 volts is present on the pad from sniped pin 14 without having to link it.
Perhaps the SUP just needs a tone or something shoving up it to switch it on. It would then only need the feed through power removing.
73 Tony G0AZQ.
73 Tony G0AZQ.
