70cm Digilite Builds
M0ATV
Post by M0ATV » Fri Dec 23, 2011 10:01 pm
Just wondering as to other peoples experience with their 70cm digilite, how are you finding the difference between 23cm distance/ranges compared to 70cm, Im almost finished my build & have never used 70cm for ATV before so it will be a first for me.
Also have edited the pic showing the parts that are unique for 70cm build, there is also one or two caps underside that are different values compared to 23cm build, since the info relating to the 70cm build is extremely vague & as some have stated quite confusing due to the number of postings relating to the subject, here is what I have gathered for the poor souls having a go at the 70cm build....
Part Value
IC3 AD8345
2mb/s parts spec
L1 12uH
L2 15uH
L3 12uH
L4 15uH
C13,C15,C16,C18 560pF
C14,C17 2n2
Would be a hell of a lot easier if there was a seperate parts listing download/spec for both 23cm & 70cm build I would have had mine built a few months earlier .
Please correct me if I'm wrong, Cheers................Tony
Return to “DigiLite”
