Construction Progress
G0KTD
Re: Construction Progress
Post by G0KTD » Tue Oct 18, 2011 6:15 pm
Hi all I have started my Digilite board Sunday Night I am about 90% complete found that part number for
C10 C23 C26 is the wrong what came from farnell was Part number 113-5233
AVX - TCJB107M006R0070 - CAPACITOR, CASE B, 100UF, 6.3v
Case F as is called for on the board.
apart from that seems to be going well waiting for IC to arrive and find the right caps managed to fit L5 OK it is very small
Hope all goes well on this one then to do one for 70 CMS portable use.
Keith G0KTD
M0ATV
Post by M0ATV » Wed Oct 26, 2011 3:18 pm
Well 18 days after start, I finally managed to RX my own digital signal on SAT RX upstairs, what a nightmare it was getting GBPVR & digilite software running properly on this old PC, but it worked in the end, still only very minimal pwr output at the moment, but at least its working.
g7lwt
Post by g7lwt » Fri Oct 28, 2011 10:41 am
Hi Tony,
it was good to see your pictures via G3SMU (on the http://g7lwt.camstreams.com video stream) last night.
There was minimal breakup due to RADAR, once you're running a little more power, the video will be solid. The video quality was wonderful, typical DATV P5.
Well done and thanks for all the news on progress, hopefully a few more users will join us on Digital in IO83 now.
73 de Darren
G7LWT
G0KTD
Post by G0KTD » Fri Oct 28, 2011 7:04 pm
Well Done Tony and thanks for pics mine is all but complete waiting for L1 & L3 to come taking ages through the post then some testing
Keith G0KTD
M0ATV
Post by M0ATV » Fri Oct 28, 2011 8:22 pm
thanks guys, hope to see some digital sigs on air soon as more people finish their boards as well, with my digilite board ( with mar-6 device ) fed into M68719 brick amp, then from that fed into 2x 286S amp its giving me just under 5w out at the moment, so plenty to work with till driver amp built to feed the main 2 amps.
G0KTD
Post by G0KTD » Mon Oct 31, 2011 11:37 am
Well should be able to start testing now the 5.6uh Axial Color Ring Inductors has arrived
had 50 turn up so if any body want sum send email to me and will post them off.
on4bhm
Post by on4bhm » Mon Oct 31, 2011 10:21 pm
Is there another alternative for buying the components with farnel?
They only accept company's...
Any web store where i can find all the ordinary parts? without being a company....
any info welcome....
thanks
on4bhm (at) telenet.be
73's
Post by G4EWJ » Tue Nov 01, 2011 10:26 am
Maybe it's different in Belgium, but in UK anyone can order from Farnell with a credit card. There's a minimum of £20 + VAT, but no postage costs. Farnell have a warehouse in Liege.
Other options in UK are http://cpc.farnell.com/ but they don't have the same range and http://uk.rs-online.com/web/
RS also have http://be01.rs-online.com/web/
on4bhm
Post by on4bhm » Fri Nov 18, 2011 8:00 am
My digilite project on 1249Mhz works...
With only the mar6, i can work on0snw repeater. i'm only 2km away from on0snw... :)
I'm testing now several fec's and sr's...
Is this a first for belgium to work with digiLite?
73's
on4bhm
sysop of on0snw
www.on0snw.tv
Post by G4EWJ » Fri Nov 18, 2011 11:17 am
Good news and good DX :)
I think you are the first ON to transmit with DigiLite.
Return to “DigiLite”
