How do I figure out what the address would be to place a link on my web page directly to my Member's Stream page?
Jake WF8S
Web link to my stream
Re: Web link to my stream
There are two ways to determine the URL for your stream page. One is to search for your web stream page by member stream or repeater stream name in a search engine like Google, and see if it brings up a discrete Channel ID and stream number in a URL. Then you have a direct link to copy and paste.
Another way is to use the BATC Short URL plan. It is described in the Latest News on the main batc.tv page.
Short URLs introduced
We have introduced short URLs for your streams: if you login to the members area and select "Manage Streams" you can edit your streams details and add a short URL that can be used to access your stream as follows: http://www.batc.tv/streams/myShortURL
Hope it helps you.
Hope it helps you.
73 Raleigh AC5JW
