I'm getting ready to put GB3FT back on air and have been testing the stream output to the BATC site.
I can see FT is still listed but inactive, I've entered the credentials as they were before into the FT streaming box but so far it doesn't seem to be showing on the BATC streamer page.
Maybe something needs doing at the BATC end ?
On a related matter I understand it's now possible for users to stream into the BATC portal for GB3FT and the ryde rx built into GB3FT can pickup on this stream and transmit it.
Is the above correct and if so what do I need to do to activate this functionality ?
Thanks again Tim
Reactivate repeater stream
Re: Reactivate repeater stream
Send me an email Tim and I'll check the details.
Re stream input - yes, you'll need a separate Ryde configured as a stream rxr and a separate input stream set up on the streamer.
thanks will do
Tim
Tim
