Changing stream name
greg
Post by greg » Sat Apr 18, 2020 9:37 am
Per the title, I wish to ask if it is possible to change my stream name.
I tried using the forum search tool but was told that "change", "changing", "stream" and "name" are all too common. You might want to look into that at some point to check if your search settings are too strict.
My callsign was previously 2E0HIS and is now M0ODZ (it has been since last year). Could my stream name be changed to reflect this?
Have a great weekend
de M0ODZ
Greg
Re: Changing stream name
Post by G8GKQ » Sat Apr 18, 2020 9:55 am
Hi Greg
Not sure if users can change it, but I have just gone in as Admin and changed your stream name. It seems that this was missed when your username was changed.
So your Stream Title is now M0ODZ (upper case) and your stream output URL is https://batc.org.uk/live/m0odz (lower case), and your stream key is m0odz-xxxxxx (lower case). Not sure what case the callsign in the key was before, but this is how it should be configured
Your stream key password (xxxxxx) is unchanged from what it was.
Hope that helps
greg
Post by greg » Sat Apr 18, 2020 10:02 am
Many thanks Dave, much appreciated.
Now I just have to come up with something worthy of being streamed :P
Return to “Streaming”
