Streaming RX portsdown
F4DVK
Post by F4DVK » Sat Nov 17, 2018 9:57 am
I programmed streaming with the following code:
ffmpeg -f v4l2 -video_size "640x480" -i /dev/video0 -f alsa -i pulse \
-acodec libmp3lame -ac 1 -ab 48k -ar 22050 \
-vcodec libx264 -preset veryfast -b:v 256k -minrate 256k -maxrate 512k -bufsize 320k -s 640x480 \
-f flv "rtmp://rtmp.batc.org.uk/live/f5zbc-xxxxxx"
Streaming is clearly visible on the internet, but no video display on the portsdown.
He stuck to: "Valid Stream Detected"
Do you have an idea for my problem?
Thank you.
Stephane
Re: Streaming RX portsdown
Post by G8GKQ » Sat Nov 17, 2018 8:40 pm
Hi Stephane
I tried looking, but your stream was not there when I got back from /P operation today. I do not know what Linux version and what hardware you are using, but try the following changes:
-framerate 25 -vcodec libx264 -preset veryfast -b:v 256k -minrate 256k -maxrate 512k -bufsize 320k -s 640x480 \
-g 25 -f flv "rtmp://rtmp.batc.org.uk/live/f5zbc-xxxxxx"
Portsdown streamer uses:
          $PATHRPI"/ffmpeg" -loglevel $MODE_DEBUG -thread_queue_size 2048\
            -f v4l2 -video_size "$VIDEO_WIDTH"x"$VIDEO_HEIGHT" \
            -i $VID_USB \
            -f alsa -thread_queue_size 2048 -ac $AUDIO_CHANNELS -ar $AUDIO_SAMPLE \
            -i hw:$AUDIO_CARD_NUMBER,0 \
            -framerate 25 -c:v h264_omx -b:v 512k \
            -ar 22050 -ac $AUDIO_CHANNELS -ab 64k \
            -vf "$CAPTION""$SCALE"yadif=0:1:0 -g 25 \
            -f flv $STREAM_URL/$STREAM_KEY &
h264omx is hardware encoding.
Hope that helps
F4DVK
Post by F4DVK » Sun Nov 18, 2018 7:45 am
HI Dave,
Thanks for your help.
I tried the changes, but still no video on the raspberry.
I use a PC with ubuntu18.04 and an easycap for video input.
Thank you.
Stephane
Post by G8GKQ » Sun Nov 18, 2018 2:58 pm
Stephane
I think that the Portsdown player (actually omxplayer) is unhappy about your stream parameters. Here is the info on a stream that works:
pi@raspberrypi:~ $ omxplayer --timeout 2  -I rtmp://batc.org.uk/live/gb3zz
[flv @ 0x1dffa0] audio stream discovered after head already parsed
[flv @ 0x1dffa0] video stream discovered after head already parsed
Input #0, flv, from 'rtmp://batc.org.uk/live/gb3zz':
  Metadata:
    Server          : NGINX RTMP (github.com/arut/nginx-rtmp-module)
    displayWidth    : 720
    displayHeight   : 576
    fps             : 25
    profile         :
    level           :
  Duration: 00:00:00.00, start: 42147.110000, bitrate: N/A
    Stream #0:0: Audio: mp3, 22050 Hz, stereo, s16p, 64 kb/s
    Stream #0:1: Video: h264 (High), yuv420p(progressive), 720x576, 25 fps, 25 tbr, 1k tbn
Video codec omx-h264 width 720 height 576 profile 100 fps 25.000000
Audio codec mp3 channels 2 samplerate 22050 bitspersample 16
Subtitle count: 0, state: off, index: 1, delay: 0
V:PortSettingsChanged: 720x576@25.00 interlace:0 deinterlace:0 anaglyph:0 par:0.94 display:0 layer:0 alpha:255 aspectMode:0
have a nice day ;)
and here is the info from the f5zbc stream:
pi@raspberrypi:~ $ omxplayer --timeout 2 -I rtmp://batc.org.uk/live/f5zbc
[flv @ 0x1820fa0] audio stream discovered after head already parsed
[flv @ 0x1820fa0] video stream discovered after head already parsed
Input #0, flv, from 'rtmp://batc.org.uk/live/f5zbc':
  Metadata:
    displayWidth    : 720
    displayHeight   : 480
    fps             : 29
    profile         :
    level           :
  Duration: 00:00:00.00, start: 25280.503000, bitrate: N/A
    Stream #0:0: Audio: mp3, 22050 Hz, mono, s16p, 48 kb/s
    Stream #0:1: Video: h264 (High 4:2:2), yuv422p(progressive), 720x480, 30.30 fps, 29.97 tbr, 1k tbn, 59.94 tbc
Video codec omx-h264 width 720 height 480 profile 122 fps 29.970030
Audio codec mp3 channels 1 samplerate 22050 bitspersample 16
have a nice day ;)
I have tried to make it work in omxplayer by changing the player parameters, but have not had any success.
Please could you try:
  • Forcing the video coding to h264 (High), yuv420p(progressive)
  • Forcing 25 fps
  • Forcing Display Height to 576
I think that the first is the most difficult, but the most likely to succeed. You can try these commands on your RPi. Let me know how you get on.
F4DVK
Post by F4DVK » Sun Nov 18, 2018 9:19 pm
With the modifications it works!
Thank you.
Stephane.
Post by G8GKQ » Mon Nov 19, 2018 4:28 pm
Stephane
Please could you post here a copy of your working ffmpeg code? So that the next person can do it easily?
F4DVK
Post by F4DVK » Mon Nov 19, 2018 6:38 pm
The problem is with the "yuv422p".
I left the resolution as the original video.
This code can probably be improved.
ffmpeg -f v4l2 -video_size "720x480" -r 25 -i /dev/video0 -f alsa -i pulse \
-vcodec libx264 -preset veryfast -b:v 256k -minrate 256k -maxrate 512k -bufsize 320k -s 720x480 \
-vf format=yuv420p \
Thanks again Dave.
Stephane.
Post by G8GKQ » Mon Nov 19, 2018 8:42 pm
Thanks Stephane - good to know. Dave
Return to “Streaming”
