Page 4 of 5
Re: Stream becomes inactive regularly
Posted: Sun Dec 02, 2018 6:07 pm
by M0SKM
G1BVI wrote: ↑Sun Nov 25, 2018 4:36 pm
Also noted that stream from GB3TV has broken.
I was repeater stream hopping this am it showed a street image,
Now its just a black image,
73 and Kind Regards
Nick
GB3TV is off air and the street image is the streaming location in Leighton Buzzard.
We're patiently waiting for a fix.
Posted: Thu Dec 06, 2018 3:32 pm
by G8NZR
Latest failure today at 10:15am, followed by the 10 second loop of trying to re-connect until manual re-start at3:30pm.
73 Kay
G8NZR/GB3YT
Posted: Mon Dec 10, 2018 5:14 pm
by G8NZR
Latest problems today - stopped at 11:57 and did its 10second retry cycle until I manually reset it at 16:53.
73 Kay
G8NZR/GB3YT
Posted: Sun Jan 13, 2019 9:21 am
by G8NZR
I was just about to post saying that it hadn't failed for ages, when it stopped streaming!!
Apart from a glitch on Dec 21st at 11:18 (This restarted okay on its own), the latest fail was last night at 23:34 Jan 12 until I reset the PC at 9:13 Jan 13th. Between those times it did its 10second retry loop.
73 Kay
G8NZR
Posted: Sun Jun 16, 2019 5:02 am
by G8NZR
I'm still getting regular fails and having to re-start streaming almost everyday. It did seem to settle down at one point, but once again its back to almost everyday. Did anyone ever get any further as to why this is happening on what seems to be the GB3YT stream only?
It looks like the writing is on the wall for Flash anyway, so are there any help pages for changing it away from Adobe?
Thanks, Kay
G8NZR
Posted: Sun Jun 16, 2019 10:20 am
by G7VVF
Hi Kay,
It is quite easy to stream HTML5 with OBS
https://obsproject.com or Vmix
https://www.vmix.com . Both are free to download and use, though you need to apply for a free licence for Vmix. I am currently using OBS to stream GB3EN and IO91WN. The worst part of streaming this way is the 30-50 second delay. It seems that higher bit rates have less delay.
Duncan
G7VVF
Posted: Sun Jun 16, 2019 4:00 pm
Hi Kay
Apologies, we had to do some brief server maintenance yesterday (trying to track down why the main BATC site is so slow at the moment), and that may have caused you to need to restart.
Interested that it has been good and then started failing again. We'll keep an eye on things as we continue our work to improve the service.
Posted: Sun Jun 16, 2019 6:08 pm
by G8NZR
Thanks Duncan for the info - I'll have a look at that.
Thanks for the update Dave. It would sometimes run okay for quite a few days, then out of the blue it would fail. Yesterday and today have been non-stop failures of streaming, but I did notice there were some problems with the BATC site being very slow.
I think I'll abandon restarting until you have had chance to sort out the root problems with the website.
73's, Kay
G8NZR
Posted: Sat Oct 24, 2020 3:03 pm
by KA5BBC
I know this is an older thread however I bought and built a new RPI 3B+ based Portsdown 2020 yesterday and the stream is becoming inactive every few hours. I had been experiencing the same issue with an external stream box, which had previously been stable for days on end, so build a dedicated Portsdown to act as the main continuous stream as I build the virtual repeater.
Do I need to upgrade to the Portsdown 4 as my main repeater streamer or is this a known problem with an easy fix?
Posted: Sat Oct 24, 2020 3:52 pm
Andy
The Portsdown 2020-based stream receiver is stable, but depends on the quality of the stream going into the BATC server and on the local internet connection.
The GB3HV transmitted stream has been running for many weeks now without a problem (Potsdown 2020 on a Raspberry Pi 3), and today I monitored 7 hours of the BATC CAT20 on my Raspberry Pi 3B+ Portsdown 2020 without interruption.
