Loss of repeater streaming channel
Post by g8gtz » Wed Feb 05, 2014 11:13 am
A couple of repeaters have recently lost their streams.
This is because the membership of the registered stream owner lapsed which then causes the streams to be deactivated. The repeater stream is reactivated but for obvious reasons members cannot put their streams back under the repeaters channel and without checking the 900 member database we don't know who has a repeater channel allocated to them.
I guess the real answer is not to let your subscription lapse, but if you do and your repeater disappears the stream owner should send an email to admin or tech at batc.org.uk asking for it to be re-instated.
Return to “Streaming”
