Streaming using Raspberry PI
G8PUO
Post by G8PUO » Mon Sep 04, 2017 2:06 pm
Looking at the excellent Portsdown project and interested to follow up on streaming using the PI.
https://wiki.batc.tv/Streaming_to_batc. ... spberry_Pi
https://wiki.batc.tv/DATV_Equipment_Shopping_List
The Portsdown list states using a PI 3. However, my question is, if just streaming and nothing else, can an older PI be used?
G8PUO http://g8puo.com
HAMKit http://hamkit.co.uk
RILGES Repeater Group http://rilges.org.uk
KRG - Kent Repeater Group http://krg.org.uk
sean2e0saf
Re: Streaming using Raspberry PI
Post by sean2e0saf » Thu Dec 14, 2017 1:42 am
can streaming using a raspi still work using a sat rx.. or is it portsdown only
23cms AATV from io83qn ( wn68ns )
23cms DATV from i083qn ( wn68ns )
70cms DATV from io83qn ( wn68ns )
wimo shf-2344
parabeam 70cms/18ele
Post by g8gtz » Thu Dec 14, 2017 9:22 am
Hi Sean,
Don't quite understand the question but if you feed the composite video out (yellow phono / SCART) from the Sat Rx in to the composite input on the Easycap dongle on the Portsdown and set it up as described on the wiki https://wiki.batc.tv/Streaming_to_batc. ... spberry_Pi whatever is received on the Sat Rx will be streamed on batc.tv.
73 Noel - G8GTZ
sean2e0saf
Post by sean2e0saf » Mon Jan 08, 2018 3:45 am
are the raspi cards still available and what is the best raspi to use..?
wimo shf-2344
Post by g8gtz » Mon Jan 08, 2018 8:33 am
The raspi is not a card - it's a standalone Raspberry Pi - take a look at this page with full details of the hardware and where to get it from: https://wiki.batc.org.uk/Portsdown_hardware
You will only need the Rpi + Easycap video capture dongle + SD card and maybe the touch screen to do video streaming as described here: https://wiki.batc.org.uk/Streaming_to_b ... spberry_Pi
I'll reply re the filter shortly.
Post by G8GKQ » Mon Jan 08, 2018 11:29 am
Hi Sean
You will need a Raspberry Pi 3. The older versions might just work, but are not supported.
sean2e0saf
Post by sean2e0saf » Mon Jan 08, 2018 1:11 pm
ok so raspi v3 and i need the preloaded sd card..!
these are still obtainable from the shop are they ..???
wimo shf-2344
Post by G8GKQ » Sun Jan 28, 2018 3:21 pm
Programmed SD Cards are still available from the shop.
G8DKC
Post by G8DKC » Fri May 25, 2018 8:05 am
Hi Dave G8GKQ,
Letting you know, GB3GQ will be streaming from Pi later today.
Just getting use to the Portsdown software menu :)
Thanks for all the work on the project, and the Batc Wiki...
Peter
G8DKC
Streaming using Raspberry PI GB3GQ
Post by G8DKC » Sat Jun 02, 2018 8:11 am
Was going to setup Pi 3B+ because Pi stopped streaming intermittently, before I did, replaced PSU now > 5.1v.
I was using a unbranded 5v 2.5 Amp supply, ~ 4.8v, now Pi Hut one all OK, will use a more professional PSU on final build.
If all else fails Read the Wiki :)
Also changed 12v power supply to repeater controller to drastically reduce noise from repeater to Pi streamer.
This is not noticed when streaming to old Batc dot Tv server using Adobe Flash Encoder...
Maybe earth loop?
So far
Peter
Return to “Streaming”
