Stream input installed
Locator: IO93WT
Post by G3GJA » Sat Aug 31, 2024 4:01 pm
GB3EY now has an Internet streaming input, following re-programming of the Raspberry Pi formerly used to play out HD videos.
A key can be obtained via email to clive@hesh.co.uk. Note that if you are not personally known to one of the Committee you will be asked to provide a copy of the first page of your Ofcom licence.
Whilst on the bench, a fault causing low output power was traced to an oxidised joint where the input of the circulator was soldered to the output track of the final RF amplifier PCB and a reduction of the glitches when switching inputs has been achieved by reconfiguring the HDMI switches so that one of them acts as a frame buffer feeding the encoder.
Enjoy the new feature!
73, Clive G3GJA
M1ASR
Re: Stream input installed
Post by M1ASR » Mon Sep 02, 2024 9:46 am
Great feature Clive.
Return to “GB3EY”
