Hand soldering on thin Rogers PCB
I am looking for advice on hand soldering SMDs onto a thin Rogers PCB. My problem is that I can't get enough heat into the joints as the heat is being conducted away rapidly through the thin substrate into the ground plane layer underneath. A large soldering bit is impractical. I have become quite competent with FR4 boards and components down to 0402 size but this Rogers material is proving difficult. I have considered the idea of working with the PCB on top of a hot plate at 100 degrees or so but that might prove painful! Ideas will be gratefully received.
Russ, G4SAQ
Russ, G4SAQ
Re: Hand soldering on thin Rogers PCB
Interesting....never really thought about it as an issue.
I've just built a pair of G4DDK preamps which are on normal FR4.
I did buy fine bits for sma but found I could solder everything better with my usual 2.3mm chisel bit. That's on my Weller TCP so it's got 50 watts if needed. Temp 7. For bigger stuff I've got a large 9 which is very capable.
What are you building?
Hi Gareth,
Like you, I've built a DDK VLNA without issue but this job is proving awkward. It's a 600W SSPA - W6PQL design. Some of the components have been ok to solder but resistors on the wide input lands are difficult. I'm using a 50W temp controlled iron and a 3mm bit will not put enough heat down. I have a larger bit but it will make a mess. My 80W iron is the size of a poker!
Russ
Russ
Hi Russ - the trick is to heat the board up on a hotplate first. Less heat needed then.
Thanks Mike. I asked CHAT Gpt the question an hour ago and that also suggested a hotplate or coffee warmer. Luckily I bought a hotplate and aluminium billet for soldering the LDMOS device to the copper heat spreader (it worked a treat). I'll try the hotplate at 60 C initially and see how that works.
Russ.
Russ.
My Chinese hotplate is set to 230 C. It could be a tad lower but components just self center nicely using solder paste hand applied first.
Ex G6ANG/T and G8EAO
Thanks Dave. I'm hand-soldering these parts at the moment but I'll be doing it on top of the hot plate. Thankfully, it will all fit under my microscope!
Russ
Russ
PLeased to report that I've now populated one of the boards. I kept it on a hotplate about 90 deg C whilst hand-soldering with an iron at 410 deg C. The solder flowed nicely and I managed to avoid a visit to the burns unit
Russ.
Russ.
