Hi all, few around VK have got onto the Osee Gostream.
Very similar to the Atem Mini Pro.
Main claim to fame I feel is the 2 HDMI outs.
4 HDMI Ports In, USB C Network, Audio In etc.
It can be used without a PC with its Built in Menu System.
Can Stream RTMP and 2 Others simultaneously.
Can record and Playback to SD or SSD (new firmware recently 2.1)
Compatible with OBS, Companion, and PC software just released.
Has good support on private Facebook group.
A lot of features I wish the Atem could have had.
And the Price that's Greats, look around.
Won't SPAM the thread with Hype and Links Google and YT is you friend
New model to be released soon with SDI ports.
My fav is the T-BAR for that look and works
Cheers
vk3ie
Osee Gostream Atem Killer (some say)
Re: Osee Gostream Atem Killer (some say)
Thanks Rob, that's a tempting device for sure! I was pondering an Attem, but now I think these may be better value and much more feature rich.
Is it 4k? Price seems to be around $300. What can you do via the ethernet port?
1080 only, ethernet for streaming and PC control
https://osee-tech.com/products/gostream-deck
Cheers
vk3ie
Basil
I have the Atem Pro but this with the 2 HDMI is the deal.
One for TXer and you other to monitor is the winner
and all the other features,
The Only issue it does get Warm Hot on the underside, a small fan on the side,
or sit upon 120mm fan does the job with ease.
Apparently next model with SDI etc will have a fan.
Cheers
vk3ie
