In the non-repeater contests, do you change the 4 digits for each new contact, or keep them the same? I ask because I'll make up a sample to take with me, observing the rules about non consecutive numbers and not repeating a number in the group, of course, if I need to change it for each contact as, if doing it 'on the fly' I might forget the no repeated digits and no consecutive numbers rule in the heat of the moment.
I guess that, reading the rules for the Repeater contest, you need to use a different set of 4 digits per repeater, so if you use two repeaters you will have two groups of numbers and possibly a different resultant number from the addition process. So, where do you put the second set of numbers please, as the log sheet I downloaded only has one box to put them in?
Thanks for any help, advice or clarification on this.
Dave (G0DJA)
