Pluto maybe used as a Digital Frequency Converter to move a chunk of spectrum up to ~2.5MHz bandwidth from one band to another. This example shows reception of a 8Degree sidelobe of a 6cm DATV DVBS2 transmission from G4FRE over a 17.5Km path between Malvern and Tewkesbury using a Portsdown4 and Minituner tuned to ~2322.5MHz.
The technique of shifting chunks of spectrum is very useful as it opens up possibilities of DATV reception on frequencies outside the tuning range of the Serit tuners used in various projects.
Degradation of signal was crudely assessed by converting the QO-100 beacon IF from a non-locked LNB at ~742MHz to 2322.5MHz improving the MER by ~0.4dB.
The GUI shows the spectrum display of G4FRE's 5762.5MHz signal, blue line is the live spectrum, green line is with the maximum hold function enabled. (This is very useful in peaking the dish as the 'best' can be easily observed). If '0Hz offset' is selected a receive frequency can be directly entered otherwise it serves as an offset for fine tuning.
Caveats on this technique are:
- Certain frequencies will not work e.g. When the RX and TX are close together, when the RX is a multiple of the TX
- Band Pass Filters maybe needed for reception in some circumstances
- Approx. 30dB of attenuation is needed between the Pluto TX output and the Serit tuner input
- If the TX output is connected into an antenna then it should be remembered that the whole of the bandwidth converted will be transmitted plus harmonics
I used GRC v3.7 with gr-iio blocks on a i5 windows10 PC
Steve G4NZV
Pluto as a Digital Frequency Converter
- F1F2 GRC blocks.PNG (120.02 KiB) Viewed 2222 times
- G4FRE 250KS 20210323.PNG (42.11 KiB) Viewed 2222 times
- G4FRE 6cm 20210323.jpg (81.05 KiB) Viewed 2222 times
Re: Pluto as a Digital Frequency Converter
Nice,
I still struggle with gnu radio to understand the simple thing of getting it to work for me..
I see ideas of DATV relays 70cm in and 13 cm out using a pluto and a raspberry.
Any chance you create some image for a RPi to download and start easy?
Best regards Benno
Best regards Benno
I like the idea of using a Raspberry Pi4 & Pluto as a Digital Frequency Converter and I am working on a solution.
However, there is still an unresolved issue when using the Pi4 in that the TX output spectrum has discontinuities. IF the Pi4 work is successful I am happy to share the .grc file and will investigate the possibility of providing an image.
Steve G4NZV
Steve G4NZV
Yes this works well.
You can make some very sharp filters in software to remove unwanted signals close in to the desired one, like we have on 2m and 70cm for example.
