Mini Tiouner Caps.
g4mqs
Mini Tiouner Caps.
Post by g4mqs » Thu Jun 18, 2020 12:07 pm
Hi, building up the mini tiouner but the caps C3,4,6,7 state they must be low ESR but the part numbers for Digi-key are not. Searched everywhere but cannot find 22u 50v caps with an ESR less than 1 ohm? Any suggestions?
Paul
DG8KD
Re: Mini Tiouner Caps.
Post by DG8KD » Thu Jun 18, 2020 1:42 pm
Post by g4eml » Thu Jun 18, 2020 4:35 pm
In practice I don’t think it is that critical. I used standard electrolytics in my minitiouner and it works fine.
Post by g0mjw » Thu Jun 18, 2020 5:37 pm
The regulators specify a low ESR but I would think anything reasonable would be fine. Just don't use 50 year old stuff from the junk box. I used the ones from Digikey.
g4mqs
Post by g4mqs » Sat Jun 20, 2020 10:50 am
Hi Paul,
easiest way:
https://www.ebay.de/itm/4-pcs-Elite-Elk ... Sw-zxWo2zt
Thanks, have sent off for these. Paul
g4mqs
Post by g4mqs » Sat Jun 20, 2020 10:51 am
Thanks guys. The digi-key ones are no longer available, hence the hunt. If the German ones don't arrive I have some similar and will drop those in.
Paul
