Activity March 20/21 Repeater contest?
Post by M0DTS » Mon Mar 01, 2010 11:23 pm
Hi All
Just posting to see if there will be anyone else thinking of portable activity over this weekend?
Hopefully i'l be out on the Saturday with 23cm Analogue and 70cm Digital TX/RX from the North Yorks Moors.
The main plan is to try some Digital tests on 70cm but will be monitoring 23cm GB3VL and GB3EY for activity, possibly GB3KM if i can get a link setup to get over the hill... There is rarely anyone on on a contest day anyway mind......... ;-)
Anyone else going to join in if the weather looks reasonable?
Re: Activity March 20/21 Repeater contest?
Post by G4EWJ » Fri Mar 12, 2010 2:42 pm
I won't have any gear, but I might go out into North Wales on the talkback channel and see what the paths are like for future reference.
Do you have an NGR for where you're likely to be?
Post by M0DTS » Sat Mar 13, 2010 1:49 pm
Hi Brian,
I'l probably be at SE613977 (IO94LI) as last weekend's session at IO94MJ did not yield the results i expected, too much breakthrough from Bilsdale UHF stuff on the receiver to make anything out around 1310MHz. May do some more tests tomorrow with a filter and better preamp and see what happens...
May not go out yet, depends if i get at least one reply from someone going to be on..
I'm not too bothered about repeater contest so would be nice to have some direct QSO's!!
Post by M0DTS » Fri Mar 19, 2010 11:36 am
Hi All..
I will not be active on Saturday as planned... virtually no response to my activity request and it's probably going to rain..
Post by G4EWJ » Fri Mar 19, 2010 3:21 pm
I might have a run out to Cyrn-y-Brain (SJ213493) near Llangollen and have a listen around anyway.
Post by M0DTS » Fri Mar 19, 2010 10:47 pm
I'll be still around from home so will be monitoring 144.750.
Post by G4EWJ » Mon Mar 22, 2010 9:29 am
I didn't make it in the end. When I reached the highest point of the main road, the visibility was below 100m, so I decided that another 500 feet of elevation probably wasn't wise.
