Page 1 of 3
				Laptop display used to make a monitor
				Posted: Wed Nov 29, 2017 1:13 pm
				by G4CPE
				There appears to be several display adaptor boards available on Ebay to make use of laptop displays to make a decent VGA/HDMI monitor.
I have ripped apart a faulty 17inch laptop and removed a Samsung LTN170X2-L02 display which appears on the lists of suitable display types for several adaptor board kits for VGA/HDMI.
Has anybody found a display board kit that supports composite video input so the monitor could be used directly with 5GHz FPV receivers.?
Arthur G4CPE
				Re: Laptop display used to make a monitor
				Posted: Wed Nov 29, 2017 3:11 pm
				by G8JAN
				Arthur if you download and install NCH DEBUT from the NCH website on to a laptop or any other PC, you can imput video via an AV socket or an S video socket. If you have a 5 GHZ RX with USB output you can imput video via a USB port. The NCH software is a freebie. I'm currently using a 5GHZ scanning RX with a  USB output to my PC's and it works a treat.
Pete
G8JAN
				Posted: Wed Nov 29, 2017 4:40 pm
				You can get HDMI->A/V and A/V->HDMI adaptors on ebay for £5 to £5.
e.g. search for "AV2HDMI Composite AV CVBS 3RCA to HDMI 1080p Converter Adapter Video Upscaler HD"
				Posted: Wed Nov 29, 2017 5:59 pm
				by G4CPE
				Thanks Pete / Mike
Take a look at eBay item 272086508548 this chap (odie 2018 ) lists a load of panels that should work with his controller board.
The board appears to have a variety of input options including AV
73 Arthur
				Posted: Wed Nov 29, 2017 7:16 pm
				by g8gtz
				There's an article in next CQ-TV (due out before Christmas) based on John G7JTT's good experience of using exactly one of those type of devices for an old scrap laptop screen.
The device he used was this one form ebay USA
https://www.ebay.com/itm/271757526668?ul_noapp=true
73 Noel - G8GTZ
				Posted: Sat Dec 02, 2017 10:07 am
				by G8JAN
				Thanks Noel interesting find!
				Posted: Tue Dec 26, 2017 3:23 pm
				by G7JTT
				Hi all just an update to the article in CQTV, I've now boxed the screen by using 35mm X 20mm aluminium angle and added speakers to the board as well. The angle is rapped around the screen by cutting V's out of the 20mm sides at the corners and bending it along the 35mm side to form a right angle.
https://www.dropbox.com/s/eiwkukb8rqi2u ... 8.jpg?dl=0
The buttons are fitted to the top along with the power LED and IR sensor
https://www.dropbox.com/s/6irlv9y0n2abx ... 9.jpg?dl=0
And a slot is cut to gain access to the inputs.
https://www.dropbox.com/s/stkpydl7nb2uw ... 1.jpg?dl=0
The whole lot is held together with hot glue, just need to find a bit of plate to enclose the back.
all best John G7JTT
				Posted: Fri Dec 29, 2017 4:21 pm
				by G4CPE
				I received my controller board today. It powers up OK and gives a picture on all inputs put the colours are wrong (red grass etc.) I think it is the same problem that John encountered with his display at first. I have sent a message to the supplier in the hope he can send the required fix.
The controller has all the inputs required including analogue TV. the laptop screen that I have used is a 17inch  LTN170X2-LO2 which the supplier claims will work with this board. I hope to report success soon.
73 Arthur
G4CPE
				Posted: Sat Dec 30, 2017 10:33 am
				by M0DTS
				I ordered one for a laptop screen using the same chip.
It came with all UI in Chinese, took some time to navigate menu's to set it to English!!!
Anyway it does have the option to disable blue screen, but then i just get a black screen on a noisy composite video input
The tuner input does however show noise though so i can probably utilise that input instead, is this expected or should i have noise on the composite input?  if so i may also have to look at different firmware.
Liking the idea of the alu frame, may have to copy that
				Posted: Sun Dec 31, 2017 10:56 am
				by G4CPE
				Hi Rob
It would appear that the blue screen is simply changed to a black screen but with a video mute still applied. I have also found that if an RF modulator from a VCR is used on the TV input then it does display a noisy signal without muting the video so this may be a work around solution.
The display that I get is poor at the moment with colours all wrong I am waiting for a reply from the supplier and am hopeful that he will be able to supply a firmware change to fix the problem. Is the video display correct on your screen. ?
73 Arthur
G4CPE
