146MHz NOV.
146MHz NOV.
Post by G4EWJ » Mon Oct 02, 2017 5:56 pm
Are the 146MHz NOVs being renewed at the end of this month?
M0YDH
Re: 146MHz NOV.
Post by M0YDH » Mon Oct 16, 2017 6:53 am
I'd like to know too before I buy any amp from Mini-kits and start the 2m setup of my station.
Dave and Noel help please.
David M0YDH
Re: 146MHz NOV.
Post by g8gtz » Mon Oct 16, 2017 7:37 am
Word from the RSGB convention yesterday was that the renewal process for another year's NoV will open shortly.
Re: 146MHz NOV.
Post by g0mjw » Mon Oct 16, 2017 5:40 pm
Anyone for 71MHz locally?
G4FRE
Re: 146MHz NOV.
Post by G4FRE » Tue Oct 17, 2017 11:40 am
My gear is ready but the NOV process has been changed on the rsgb web site; you need to have been issued an SRP before you can even start to apply for the NOV. The SRP seems to be intended to get higher power from a fixed location, judging by the v/m calculations at your neighbours fence needed, so you would need an SRP for every portable location!
Back to getting my 24GHz equipment checked out I think
G4FRE
Re: 146MHz NOV.
Post by g0mjw » Tue Oct 17, 2017 11:52 am
I would encourage you to fill it in. It's general purpose, but I think for this application its OK if you are only applying for a low ERP. Best ask Murray but 100W ERP would be a reasonable starting point. The NOV allows temporary, alternative and mobile use with geographic exclusions, i.e. not closer than within 40km of Scotland, not maritime mobile or in any other country.
M0YDH
Re: 146MHz NOV.
Post by M0YDH » Fri Oct 20, 2017 9:53 pm
Alerted by Noel, I went here
http://rsgb.org/main/operating/licensin ... 47mhz-nov/
It took 3 minutes for the 17-18 NoV :D
I can now plan to build the 2m station
David
