G7MRF Test card generator
M1PRO
Post by M1PRO » Wed Jul 12, 2017 10:06 pm
Hi All,
As im plodding along with my ATV projects that are nearly finished. I have two G7MRF Test card generators both are programmed with other person callsign.
I have a CD that was supplied with one of the units I bought.
Is there anyone out there who be willing to help me re program them. Be it meet up or Im willing to post the IC's and disc.
If anyone can help me out I would be very grateful.
Thanks Jason
Re: G7MRF Test card generator
Post by G4EWJ » Thu Jul 13, 2017 5:16 pm
I can't find any reference to it on the web. Which chips does it use?
M1PRO
Post by M1PRO » Thu Jul 13, 2017 8:38 pm
Hello Brian,
Thanks for the reply!
Yes I also googled it and found no referance for G7MRF.
The IC's are marked as m5l2764k & D2732A-2
Jason
Post by G4EWJ » Thu Jul 13, 2017 9:00 pm
Windowed eproms I believe. I think I can still program those. Is it possible to upload the contents of the CD somewhere, as a first step?
M1PRO
Post by M1PRO » Thu Jul 13, 2017 9:31 pm
Hi thanks for the reply.
Uploading to a shared point is beyond me LOL
If you ok with the suggestion, could I send you the eproms and disk and see what you make of it?
Jason
G0NMY
Post by G0NMY » Thu Jul 13, 2017 10:35 pm
The G7MRF Testcard generator is the Cropredy test card generator using eproms for the testcard.
the program to create the cards is called cropedit it is in the download section.
http://www.batc.org.uk/cq-tv/software/cropedit.zip
Post by G4EWJ » Thu Jul 13, 2017 10:39 pm
Yes go ahead. I'm QTHR everywhere, although the postcode is CH rather than L if the source is very old.
Post by G4EWJ » Fri Jul 14, 2017 9:29 am
Thanks Mark.
>> An IBM or compatible computer, DOS 3.0 or later,
>> A mouse and standard (int33) driver software,
>> A VGA or SVGA monitor.
It'll be interesting to see if I can find anything it will run on.
G0NMY
Post by G0NMY » Fri Jul 14, 2017 1:20 pm
I run it under DosBox works fine on Vista and Win7
http://www.dosbox.com/wiki/Dosbox_and_Vista
This is a screen capture of it running in DosBox on Vista
Hope that helps
:D
G0NMY
Post by G0NMY » Fri Jul 14, 2017 3:11 pm
https://www.dropbox.com/s/tpe8bd23b4dvi ... O.BIN?dl=1
Use BinHex.com Dos program to convert to a hex file for writing to the eprom.
