habamp use as amp for a DTX1 ??
G4HTZ
Post by G4HTZ » Fri Oct 10, 2014 2:52 pm
just getting the bits together for 70cms DATV
bought a DG0VE converter and have a tetra amp on its way
on the TX side am considering the DTX1
I have a HABAMP which i was going to use as a preamp before I bought the DG0VE converter
would the HABAMP be suitable to use as a amplifier for the DTX1...it produces about 27dbm at 70cms followed by a filter...if so I could use this as a low level drive for the tetra amp
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
Re: habamp use as amp for a DTX1 ??
Post by M0DTS » Sat Oct 11, 2014 7:13 pm
Hi Steve,
The HABAMP will give about 30mW from DTX1 if the gain figures are correct.
But the problem looks like the filter, it rolls off by about 5dB from 437-438MHz where we normally operate.
G4HTZ
Post by G4HTZ » Sat Oct 11, 2014 8:11 pm
Ok rob
Thanks for info
Steve
Steve G3GHZ
5665 ATV FM
2E0DTX
Post by 2E0DTX » Sun Oct 12, 2014 10:33 am
Hi -
Why not take a look at the filter here http://www.dtx1.info/NewProducts.html
The DTXF-70 would be the one to look at.
73's
Laurence 2E0DTX
G4HTZ
Post by G4HTZ » Sun Oct 12, 2014 6:02 pm
Need to get power up from the -5dbm to a few watts ...will need a amp of some kind to take the low level
Steve G3GHZ
5665 ATV FM
g4wvu
Post by g4wvu » Mon Oct 13, 2014 7:35 am
IIRC the Nokia Tetra amplifier lumps can be driven from as low as -15dBm if you include all the drive stages - don't have details to hand but will look out shortly.
g4wvu
Post by g4wvu » Mon Oct 13, 2014 9:09 am
On Robs site some details specifically low level drive
http://www.m0dts.co.uk/?tag=432MHz&item=68
G4HTZ
Post by G4HTZ » Mon Oct 13, 2014 1:42 pm
Yes will have to investigate that mod further
Cheers
Steve
Steve G3GHZ
5665 ATV FM
g4wvu
Post by g4wvu » Tue Oct 14, 2014 7:32 am
Good luck - I will be doing similar when I get around to modifying the Nokia lump I have here. I will look to about 0dBm level as I have a MMIC drive amp in my DTX1 to raise it to a comparable level as an SR Systems TX (max about +6)
I will leave high bias level on the amp as original I think (linearity)
73s
Mark
G4HTZ
Post by G4HTZ » Tue Oct 14, 2014 4:11 pm
Ok mark
May be possible to work you on 70cms atv some time
Often get gb3lo and TN down here on 24cms with a slight lift
Good luck with tha amp ...still waiting for mine to arrive
Regards
Steve
Steve G3GHZ
5665 ATV FM
