Comtech 13cm DIP switch
M0IKB
Post by M0IKB » Mon Jun 24, 2013 9:25 am
Hi, wondering if anyone out there has a copy of the dip switch settings for the Comtech 13cm TX, that they could let me have?
Its part of a 10Ghz ATV system I have put together but I havent got a copy of the dip settings for setting the TX frequency.
Many thanks
Gus M0IKB
Re: Comtech 13cm DIP switch
Post by g8gtz » Mon Jun 24, 2013 10:17 am
Hi Gus
I have the info - email me at chairperson @ batc.org.uk and I'll send it to you.
I wonder if it would be a good idea to start an online collection of useful manuals where people can put any they have.... thoughts??
Post by G8GKQ » Mon Jun 24, 2013 10:48 am
Hi Noel
An on-line collection of this sort of info sounds good, as long as we don't run into copyright issues. We could do it on the existing website to get it started....
G4KLB
Post by G4KLB » Mon Jun 24, 2013 11:33 am
It depends who the supplier was.
The G1MFG and the 13cm.co.uk ones are a mirror image of each other, so if you don't get the frequency you were expecting switch all the dip switches the other way round.
If it came from Mobicomm they are different again. So some experimenting may be required at first.
Last time I looked the switch settings were on the 13cm.co.uk site http://www.hamtvstore.com/Wide_and_Tx_settings.pdf (this will effectively also tell you the G1MFG settings)
The Mobicomm settings are also on there website http://www.mobicomm.com/store/DFM2400TSIM-B.pdf. or http://www.mobicomm.com/store/FrequencyL.pdf
I am using a custom chip for 10G (Part of a SCART Club Project) if you think you have one of those. I have the settings, just let me know and I will post them here.
Colin G4KLB
G4KLB
Post by G4KLB » Mon Jun 24, 2013 12:16 pm
SCART CLUB 10G Project dip settings
The page formatting is messed up when I post on the forum, but the information is there.
PIC Channel selector for the COMTECH 13cm TX
Section A Intended as a wire per selection of the key channels used in 10GHz for
repeaters and some simplex channels …... UK allocations
DIP sw Frequency GHz 2.5Ghz
  1     10.065        2.51625
  2     10.24         2.56
  3     10.315        2.57875
  4     10.34         2.585
  5     10.425        2.60625
  6     10.369        2.59225
  7     10.28         2.57
  8     nil ..... used to set section B
Section B Binary selection using only the first 7 DIP switch 10MHz RASTER
10Ghz freq. 2.5Ghz freq. DIP sw - 1 2 3 4 5 6 7 8
  10.015      2.50375              0 0 0 0 0 0 0 1
  10.025      2.50625              1 0 0 0 0 0 0 1
  10.035      2.50875              0 1 0 0 0 0 0 1
  10.045      2.51125              1 1 0 0 0 0 0 1
  10.055      2.51375              0 0 1 0 0 0 0 1
  10.065      2.51625              1 0 1 0 0 0 0 1
  10.075      2.51875              0 1 1 0 0 0 0 1
  10.085      2.52125              1 1 1 0 0 0 0 1
  10.095      2.52375              0 0 0 1 0 0 0 1
  10.105      2.52625              1 0 0 1 0 0 0 1
  10.235      2.55875 The center section of the    (0 1 0 1 0 0 0 1)
  10.245      2.56125 band is not available        (1 1 0 1 0 0 0 1)
  10.255      2.55625 to UK amateurs               (0 0 1 1 0 0 0 1)
  10.265      2.56625              1 0 1 1 0 0 0 1
  10.275      2.56875              0 1 1 1 0 0 0 1
  10.285      2.57125              1 1 1 1 0 0 0 1
  10.295      2.57375              0 0 0 0 1 0 0 1
  10.305      2.57625              1 0 0 0 1 0 0 1
  10.315      2.57875              0 1 0 0 1 0 0 1
  10.325      2.58125              1 1 0 0 1 0 0 1
  10.335      2.58375              0 0 1 0 1 0 0 1
  10.345      2.58625              1 0 1 0 1 0 0 1
  10.355      2.58375              0 1 1 0 1 0 0 1
  10.365      2.59125              1 1 1 0 1 0 0 1
  10.375      2.59375              0 0 0 1 1 0 0 1
  10.385      2.59625              1 0 0 1 1 0 0 1
  10.395      2.59875              0 1 0 1 1 0 0 1
  10.405      2.60125              1 1 0 1 1 0 0 1
  10.415      2.60375              0 0 1 1 1 0 0 1
  10.425      2.60625              1 0 1 1 1 0 0 1
  10.435      2.60875              0 1 1 1 1 0 0 1
  10.445      2.61125              1 1 1 1 1 0 0 1
  10.455      2.61125              0 0 0 0 0 1 0 1
  10.465      2.61625              1 0 0 0 0 1 0 1
  10.475      2.61875              0 1 0 0 0 1 0 1
  10.485      2.62125              1 1 0 0 0 1 0 1
Moderation: Fixed formatting by using 'code' tags. (gm1mfn)
M0IKB
Post by M0IKB » Mon Jun 24, 2013 3:11 pm
Thanks for all the help guys.
Really very much appreaciated, but maybe pushing my luck here but......
Anyone know how to change (or has the code to program the pic) so that the LCD control board for the 23cm comtech RX (10Ghz LNB down to ~1ghz etc) shows 10Ghz?
In other words a mod so that the Controller shows instead of 1296Mhz it would show 10296Mhz?
Might as well ask, one of you may have the perfect solution.
Once again, very many thanks
regards
Gus M0IKB
