Stacking Loop Yagi's
Posted: Fri Nov 16, 2012 11:34 pm
by G4OHV
I am intending to stack 2 X 27 element 23cm Loop Yagi's.
Does anyone know the stacking distance
regards
Col
Re: Stacking Loop Yagi's
Posted: Mon Nov 19, 2012 3:58 pm
by M0DTS
Hi Col,
I have two bayed and used 75cm spacing, it is not that critical because i tried various different spacings 50-100cm when i first got them with only a small change in main lobe performance, mainly differing levels of side-lobes.
The larger the spacing the more the gain but at the cost of stronger side lobes...
Related article for VHF yagi stacking etc maybe interesting read: http://www.grantronics.com.au/docs/StkYagis.pdf
Posted: Sun Nov 25, 2012 10:26 pm
by G8ADM
Slightly negative comment from me!
The maximum additional gain you will get from stacking two antennas is +3dB
This assumes no loss in the two way splitter, antennas with an identical impedance, identical feed cables etc.
All this is very unlikely so the best improvement you will get is say +2dB
It's really not worth all the effort. It would probably be worth putting up a stack or box of four but not two.
Regards,
Dave.
G8adm
