JVL loop yagi VNA test
G4GHD
Post by G4GHD » Tue Aug 09, 2022 1:05 pm
After a few decades on the roof mast, I've now taken down my original 24cm G3JVL loop yagi and thought I'd check it out on my NanoVNA. The socket has been cleaned up and the tests were done in the clear (as best as I can manage anyhow). Results seem disappointing to me, I'd expected the SWR curve centred on 1.282GHz to be slightly wider and deeper. The other dip at 1.367GHz SWR is what I was hoping for at the lower frequency. Note the impedances too.
Obviously actual antenna performance is not defined by SWR alone, but I was surprised by the results. I'd be interested to know how they compare with others, should anyone have done such measurements.
I do remember when the antenna arrived, G3JVL enclosed a piece of paper detailing his suggested adjustment of the small tabs next to the driven element for improved SWR. Of course, I no longer have that :roll:
1367 MHz.jpg (629.42 KiB) Viewed 2678 times
1282 MHz.jpg (1015.33 KiB) Viewed 2678 times
G4GHD
Re: JVL loop yagi VNA test
Post by G4GHD » Wed Aug 10, 2022 2:59 pm
FWIW, results with the 13cm version.
