EX BBC PAL Coder
g8kgh
EX BBC PAL Coder
Post by g8kgh » Tue Feb 16, 2021 10:02 am
I have just re-joined the club after an absence of many years and now I am starting to rebuild the parts I have lying around.
I have a pair of BBC white module coders ,both seem to work and produce PAL colour from RGB bars. However I am having problems in sorting out the relay switching for the RGB picture input. The backplane has been hacked about and extra wires added for some reason. Has anyone on here got diagrams of the coder? I have diagrams of each of the modules but nothing on how they interconnect on the backplane.
Malcolm
g8lce
Re: EX BBC PAL Coder
Post by g8lce » Mon Feb 22, 2021 9:39 am
The best idea may be to donate the coders to http://www.bbctv-lpu.co.uk/technical/ or another restoration team and use a Raspberry Pi for generating test signals. The equipement of that age was difficult to work on when still in use at the end of it's broadcasting life if it was used at Outside Broadcasts where I worked.
g8kgh
Post by g8kgh » Sat Feb 27, 2021 11:08 am
I have managed to get a complete set of diagrams and setup procedures. With these to hand I changed out all the electrolytics, most of which were showing signs of ageing, and then went through the set up procedure. At the end the coder was producing reasonable quality colour bars but several of the setup pots were at one extreme of their travel. I will now go through the modules again looking for out of spec resistors etc and see if I can bring it up to scratch.
Using a Pi wont work for me for various reasons. First I need to feed in CCIR RGB and get out PAL. Second, all my TV kit runs off an SPG so the coder must also be synced to the SPG so sources can be mixed or switched easily. Third, I enjoy repairing working with old technology, no software!
Malcolm G8KGH (EX G6ANZ/T)
g8lce
Post by g8lce » Thu Apr 15, 2021 9:26 am
Quote from email I received
'I am trying to help Richard Ellis, who used to work at Pye and was very much involved with the design of the Type II scanners. He is currently involved with the preservation and restoration of the surviving examples, North 3 which is in private hands, and to a lesser extent Lo6 which is being stored by the Science Museum.
Richard is trying to contact vision engineers who used the Natlock or coders on Type II scanners. If anybody still has circuit diagrams or other manuals, it would be a huge bonus. '
Here is a picture of LO6 at Diana's wedding. (although it might be a newer LO6 )
I was working on LO5 the next one back.
