Bit of Engineering nouse pls?...
Re: Bit of Engineering nouse pls?...
Good job on the rebuild Wolfie - they are a bit on the fiddly side (I think I've binned one in the past after failing to get it back together, lol)
Brilliant, Mike - I will have a proper read of those later this week (once I've fixed the car and finished off the household DIYg0mjw wrote: ↑Sun Feb 11, 2018 7:33 am
On in other words could you implement a monopulse tracking system. Why not!
https://pdfs.semanticscholar.org/144d/e ... 911bfe.pdf
http://earthstationnotes.blogspot.co.uk ... art-1.html
When I originally acquired this dish it took me a while to work out what was going on with it, as I initially convinced myself that to make sense of the conical scanning, the receiver/control system would need to know the speed and degree of rotation of the sub-reflector - and there didn't seem to any feedback mechanism from the motor to the control electronics.
Is does have a very nice digital inclinometer (intended for aerospace applications by the look of it) on the elevation axis, but nothing for the azimuth, so I suspect that some of the electronics was stripped from it along with the control system before it came to me.
- Wolfie G8VAT
Mending things is what I do best and this was right up my street, but I didn't want to just bore everyone else to tears..
However, I'm not so hot on the construction side since I always want to leave an item open to revision/improvement later, and where possible use what I already have rather than buying more stuff. This usually means a slightly untidy and el cheapo looking build.
Dah-di-dah
Graham G8VAT
Dah-di-dah
Graham G8VAT
Haha, I know that feeling well, GrahamWolfie G8VAT wrote: ↑Sun Feb 18, 2018 6:58 pmMending things is what I do best and this was right up my street, but I didn't want to just bore everyone else to tears..
I'm tryng my very best to make my Portsdown look lke a 'project', rather then most other constructional efforts that resemble someone having filled a blunderbuss with components and fired it roughtly in the direction of the bench...
- Wolfie G8VAT
Hehe...
IN THE OLDEN DAYS... when I was a lad and all that, I remember one of the lads in our TV workshop showing how he constructed circuits in mid air.. 3D like.. then scrunched them up with paper (to prevent shorts) and pushed them in a box!
It's a method I've refrained from... so far..
I must admit that his stuff did work though.
Dah-di-dah
Graham G8VAT
Dah-di-dah
Graham G8VAT
