I was told that we had lost 13cms ATV (Analogue) can someone clarify the situation.
Please note I am on about Wideband analogue TV not narrow digital.
I look forward to enlightened replies
Cheers Mark
ah right ok Mike in that case If I opt for 2330 that would be better.g0mjw wrote:Hi Mark,
That would seem to be the case, however please try to keep away from the satellite segment around 2400 - 2410 MHz. Es Hail Sat is likely to be there next year and you might have much greater coverage than you expected!
Narrowband Linear transponder
2400.050 - 2400.300 MHz Uplink
10489.550 - 10489.800 MHz Downlink
Wideband digital transponder
2401.500 - 2409.500 MHz Uplink
10491.000 - 10499.000 MHz Downlink
The RSGB plan notes two ATV repeater outputs 2435 and 2440 MHz where there may be activity.
