DATV-Easy and DATV-Red with Windows 11
DL3RY
Post by DL3RY » Thu Dec 19, 2024 6:44 pm
Hello everybody,
I'm have been using DATV-Easy on my Windows 10 Laptop for a long time without any issues.
With my new Windows 11 laptop DATV-Easy gets no connection to the Pluto although the pluto is connected to my LAN, can be pinged with its IP address and can be connected via http. Also it's not possible to get a connection from DATV-Easy to the Pluto if the Pluto is connected to the laptop via USB.
Similar issue with DATV-Red: no connection via LAN to the Pluto. Otherwise when Pluto is connected via USB DATV-Red gets a connection to Pluto with standad IP address 192.168.2.1
I tried to disable firewall unfortunately with no success.
maybe this a problem with Windows 11, does anybody have the same experience or better a solution for that?
I'm rather disappointed that I'm not able to use my new laptop which I have selected and bought especially to get a better performance for DATV.
Laptop: ASUS TUF F15 I7-12700H, NVIDIA RTX 4050
Therefore I will be verry happy and thankful about every hint I will get.
73's and merry XMAS
Achim, DL3RY
Basil
Re: DATV-Easy and DATV-Red with Windows 11
Post by Basil » Thu Dec 19, 2024 9:43 pm
Does the Pluto still get seen and connected to by the old Windows 10 laptop?
Best regards,
g3uis
Post by g3uis » Fri Dec 20, 2024 8:18 am
You might find that subnet is disabled in W11 settings.
Post by g0mjw » Fri Dec 20, 2024 10:04 am
Have you installed the latest drivers? I found mine not working either when it had before. I installed the drivers and all OK. Perhaps a windows update broke something, as they often do.
DL3RY
Post by DL3RY » Sat Dec 21, 2024 6:38 pm
Thanks for your response.
Yes, Pluto getstill connection with the old Windows 10 laptop.
I only have one IP range for all my network devices.
And yes, latest drivers are installed.
DATV Easy is now working, but I did not understand why. DATV Easy has been running without a connection to Pluto. Thenn I started MQTT Explorer for the first time on this laptop. Suddenly DATV Easy gots a connection to the Pluto without doing anything on MQTT Explorer, I have only started that software. Since that happened DATV Easy is working.
But DATV Red kept the issue until now.
