MiniTiouner Express schematic.
Post by G4EWJ » Mon Dec 16, 2024 1:03 pm
Was there ever one available? I'm trying to fault find on a Rev B. I can't see anything on datv-express.com.
Re: MiniTiouner Express schematic.
Post by g0mjw » Mon Dec 16, 2024 4:06 pm
Google came up with a post by F6DZP from the French DATV forum that implied the tuner was an exact copy, so perhaps if that was the case and the fault is not with the 1.1V/3.3V supply, you go with the original and it will be close enough? http://vivadatv.org/viewtopic.php?f=80&t=669
Re: Minitiouner express of F6DZP
Postby F6DZP » Thu 15 Aug 2019 06:31
The MiniTiouner-Express is the exact copy of my schematic, the only "creation" of the author is how it produces the 1.1v and 2.3v.(very creative).
I have been obliged to help the author that did not understand how a MiniTiouner works, he has just made a copy of the schematic given on Vivadatv forum(Minitiouner and MiniTiounerPro) and has just removed the LNB power supply and other extensions.
So when I read on the documentation that they have "developed" the MiniTiouner-Express that make me smile.
Post by G4EWJ » Mon Dec 16, 2024 6:36 pm
Thanks. Unfortunately the problem is in the power supply.
Pa3fbx
Post by Pa3fbx » Mon Dec 16, 2024 6:41 pm
I hope you heard all the rumble about corroded jumper pins.
Apparently the older express jumpers have given up to work and supply the power to the units.
Benno
Post by G4EWJ » Mon Dec 16, 2024 9:06 pm
Thanks. I hadn't heard that. This one is OK though.
