Hi all,
Just like Colin G4KLB I have a strange thing happening with my Pluto (C/D) using 0303 firmware. Each time I use the Pluto I have to login to the Pluto, go to DATV settings and click apply. The correct settings are there on the page but unless I click apply each time I get no RF. I've had some sugggestions such as try a different browser but Firefox,Edge and Chrome all do the same. Has anyone else got this issue or even better solved it?
73 Dave.
F5OEO v0303 forgetting settings.
Re: F5OEO v0303 forgetting settings.
Are you saving the settings with the "Save to flash" button?
Martin
G8KOE
Martin
G8KOE
Just a thought, try ejecting the Pluto when the settings are correct and see if that works. It was when setting the IP address I needed to do this.
Martin G8LCE
Martin G8LCE
Martins!
Thanks for the info, 'KOE that was the answer, because "save to flash" isn't on the page the link from the index page takes you to, but is on the controller page I hadn't seen that. Every day is a school day!
73 Dave
73 Dave
