ffmpeg not 100% compliant with DVB
PE5PVB
Post by PE5PVB » Mon Nov 14, 2022 3:48 pm
It strikes me that ffmpeg's TS as we use it is not completely compatible with the DVB standard. For example, if I watch the stream with VLC player, it often takes a while before I have audio and video. I also have a Tandberg MPEG encoder and it gives an almost instant image. I also see that, for example, a professional Tandberg receiver has some difficulty with demodulating the ffmpeg signal, while it works fine with the signal from the Tandberg encoder. I assume this has to do with frame composition and timing. Has anyone ever analyzed this?
In my case I tested this with a symbol rate of 1000ks/s
Re: ffmpeg not 100% compliant with DVB
Post by g0mjw » Mon Nov 14, 2022 5:33 pm
I suspect this is true, but I can't imagine how to take the ffmpeg source code and modify it to be compliant. We have to use what is available.
PE5PVB
Post by PE5PVB » Mon Nov 14, 2022 6:08 pm
Mike,
I'm on the quest to find the differences. If anyone have info on this, please let me know. In that case I can send the info to the ffmpeg team.
VK3EHT
Post by VK3EHT » Fri Jul 07, 2023 1:50 pm
Hello Mike,
Did you work through ffmpeg's issues?
I believe the issue is to do with the stream PCR inconsistencies and possibly injection of PMT and PAT at regular intervals.
need to TS Analyse the difference between the Tandberg stream and ffmpeg generated stream?
Would be great to include a ffmpeg option to force dvb-compliance?
Regards
Rob VK3EHT
:D
Post by g0mjw » Fri Jul 07, 2023 7:48 pm
I didn't Rob - but the main thing is it works, compliant or not.
VK3EHT
Post by VK3EHT » Fri Jul 07, 2023 11:49 pm
Thanks for the reply Mike.
I thought ffmpeg development team may have devoted some resources to fix the mpegtsmux in the later releases? :D
:D
Post by g0mjw » Sun Jul 09, 2023 9:10 am
Only if they know. Perhaps raise a bug report?
