Desktop shortcut to VLC with an auto opened stream?
Basil
Post by Basil » Tue Sep 27, 2022 6:25 pm
Can I create some sort of Windpws desktop shortcut to fire up VLC and have it open up at the network stream udp://@230.0.0.10:10000 ??
Thanks.
Best regards,
Pa3fbx
Re: Desktop shortcut to VLC with an auto opened stream?
Post by Pa3fbx » Wed Sep 28, 2022 12:10 pm
Yes,
I use it every day on my home desktop...
This is my vlc link to the 1st multicast adres..
You need to modify the program path to your needs...
"C:\Program Files\VideoLAN\VLC\vlc.exe" "C:\Users\benno\Desktop\VLC WH1.lnk" --qt-minimal-view --qt-name-in-title --no-qt-video-autoresize --video-title-show udp://@230.0.0.237:9941
Or For a BATC stream...
"C:\Program Files\VideoLAN\VLC\vlc.exe" --qt-minimal-view --qt-name-in-title --no-qt-video-autoresize --video-title-show rtmp://rtmp.batc.org.uk/live/pa3fbx
Goodluck...
Benno
Basil
Post by Basil » Thu Sep 29, 2022 2:09 pm
Thanks for the detailed reply with examples Benno, much appreciated, I will have a play at the weekend, all the best!
EDIT: It's the weekend, just, and I have it working, thanks again, I will try Rogers desktop file idea now, as well, all the best Benno.
Best regards,
G8HKN
Post by G8HKN » Fri Sep 30, 2022 9:22 pm
Basil/Chris,
Seems a bit complicated to me.
When viewing Stream on VLC go to view playlist
you should see stream listed there right click save playlist to file.
this will save a .XSPF file in documents.
create a desktop short cut to that.
Then when you click desktop short cut VLC will start with that info in playlist.
That's what I use several short cuts to Security cameras and BATC streams.
It works with rtsp streams not sure about UDP though.
73 Roger G8HKN
Basil
Post by Basil » Fri Sep 30, 2022 11:03 pm
Basil/Chris,
73 Roger G8HKN
That works fine Roger, even with a UDP stream. Very simple to implement too, and useful for other things as you said. Have a good weekend and thank you very much. Chris 2E0ILY.
Best regards,
G0NMY
Post by G0NMY » Sat Oct 01, 2022 9:36 am
If you want to stream your computer screen
<?xml version="1.0" encoding="UTF-8"?>
<playlist xmlns="http://xspf.org/ns/0/" xmlns:vlc="http://www.videolan.org/vlc/playlist/ns/0/" version="1">
	<title>Playlist</title>
	<trackList>
		<track>
			<location>screen://</location>
			<extension application="http://www.videolan.org/vlc/playlist/0">
				<vlc:id>0</vlc:id>
				<vlc:option>screen-fps=30.000000</vlc:option>
				<vlc:option>live-caching=300</vlc:option>
			</extension>
		</track>
	</trackList>
			<vlc:item tid="0"/>
	</extension>
</playlist>
Just save it as xspf file.
Basil
Post by Basil » Mon Oct 03, 2022 7:05 pm
Thanks for that Mark! BTW, do you know if there's much DATV activity on GB3UD? I keep checking the streamner but never manage to catch any. All the best. Chris 2E0ILY
Best regards,
