PlutoPlus running modified PlutoDVB firmware
m0vse
Post by m0vse » Fri Oct 29, 2021 9:09 pm
Hi all.
I have successfully compiled the latest PlutoDVB firmware together with patches from the creator of PlutoPlus to make a firmware that supports the internal gigabit ethernet port on the PlutoPlus.
All streaming functions appear to work and I can let anybody who is interested have a copy.
I am usually not a fan of Chinese 'Clone' hardware but the PlutoPlus seems to be a significant improvement on the original ADALM Pluto, with a 0.5ppm TCXO, Gigabit Ethernet and opto-isolated PTT, all housed in a sturdy metal case.
73 Phil M0VSE
Pa3fbx
Re: PlutoPlus running modified PlutoDVB firmware
Post by Pa3fbx » Sat Oct 30, 2021 6:24 am
Whoooo.. Yes... great..
Looking forward to get a copy and put it to test.
I have the plus for over 9 month on the shelf waiting for someone like you..
send you an PM for more infor...
benno
Basil
Post by Basil » Sat Oct 30, 2021 7:36 am
Thanks for your work here, I had held off buying a Pluto + because of firmware issues!
May I ask, as you are obviously very familiar with the +, does it have the same issue with boot up RF spikes as the original AD versions please?
Best regards,
Pa3fbx
Post by Pa3fbx » Sat Oct 30, 2021 7:54 am
Hay Basil,
I would guess yes as its a ripoff the same RF hardware and analog firmware..
I have never tested it, but i hardly notice the problem on my normal pluto's anymore.. But this may be caused by the drivers i use normaly and the big use of PTT out off the pluto's...
benno
VK3IE
Post by VK3IE » Sat Oct 30, 2021 8:35 am
Look forward to a test:
Robert
Basil
Post by Basil » Tue Nov 02, 2021 10:32 am
Hay Basil,
benno
Thanks benno, I am a bit paranoid about the spikes!
Best regards,
Jabi
Post by Jabi » Sat Nov 06, 2021 5:57 am
Dear Phill:
I am be very interesed in your software for Pluto Plus. If it is possible, please, send me to: jabieraru@gmail.com.
73,s de Jabi, ea2aru.
G1LPS Terry
Post by G1LPS Terry » Fri Jun 10, 2022 6:32 pm
HI All anyone have this patch or patched version they can share?
Terry G1LPS
G1LPS Terry
Post by G1LPS Terry » Fri Jun 17, 2022 1:49 pm
Terry G1LPS
Pa3fbx
Post by Pa3fbx » Sat Jun 25, 2022 9:14 pm
Phill is not responding on any call, post or mail..
But a simple google search gave me his home blog..
https://www.m0vse.uk/downloads.html
There i found a installation witch i put into the plus..
Its a Perseverance version rip off and it seems to work after some settings...
but my power is jumping up and down..
so there might be some setting or even jumper wrong...
Bedtime for now.
Benno PA3FBX
